Old 06-04-2012, 03:27 PM   #1
Stroked87K10
Stroked87K10's Avatar
87 4x4 Gauge Issues
I've got an 87 4x4. Factory gauges and stock tach(maybe not stock to the truck) Anyway i had swapped the truck for a Vette. I had the Vette a good few months then got bored and traded back for my truck again. lol Anyway the guy who had my truck for a while did some upgrades, including a tilt column. Ever since the column swap it seems the gauges are off. All the gauges worked proviously and now the temp gauge is pinned way past overheated and the fuel gauge is off as well as the rest. Other than the speedo and tach. Is there something involved with changing the column that would cause all the gauges to go whacky? Feel free to ask some questions if you need more info. I'm at a loss as far as where to start. Thanks in advance!!!
1987 K10 Shortbed 4x4 Amateur Painted Arctic White
383 Stroker w/ Turbo 350, shift kit+B&M floor shifter
Long Tube Headers with Flomaster dual exhaust
90 Burban Nose w/ Steel Cowl Hood
Blazer Buckets w/ Center Console
4"-6" lift and 35" BFG AT's
Stainless Bed Rail Bars
14 bolt FF rear Axle
Dana 44 Front Axle
Lund Roof Visor
Stroked87K10 is offline   Reply With Quote
