Old 06-04-2012, 06:57 PM   #1
peglegs
peglegs's Avatar
2004r replace a 350 in a 4x4?
I have 1987 4 x 4 with a 305/350 trans combo will a 2004r (Bowtie Trans) replace the 350? The 350 is 5/16" longer than the 200r4
ON THE SITE BELOW
http://www.crankshaftcoalition.com/w...350C.2C_TH375B
I found
TH2004R
The TH2004R transmission is the same length as a 6 inch tail housing TH350 transmission. The TH2004R requires a TV cable hook up at the EFI or carb with the correct geometry for correct operation
MY PAN IS #4
Image Number Transmission(s) Pan Bolts
1 Aluminum Powerglide 14
2 TH200 (Metric), TH200C (Metric) 11
3 TH250, TH250C, TH350, TH350C, TH375B 13
4 TH375C, TH400, TH475, 3L80, 3L80HD 13
5 TH200-4R 16
6 TH700-4R, 4L60, 4L60E 16
7 4L80E 17
Are the splines the same ?
Will the 2004r being 5/16" shorter present a problem?
Has anyone done this swap ? If so any bits of info will help thanks
1990 chevy 4x4 with a 1940 IHC body
peglegs is offline   Reply With Quote
Old 06-04-2012, 07:01 PM   #2
67swb72klb
67swb72klb's Avatar
Re: 2004r replace a 350 in a 4x4?
will not work you need a 700r4 if u want o/d in a 4x4
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 06-04-2012, 07:53 PM   #3
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
The 200 does not have a removable extension housing so a transfer case could not be bolted up to it. Your truck should have came from the factory with a 700r4 so it must have been swapped out at some time. And if you have pan #4 you have a TH400
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 06-05-2012, 12:50 AM   #4
peglegs
peglegs's Avatar
ty for the info the reason im saying 350 is the glove box build sheet said MX1=turbo 350 trans & M40 =turbo hydro-matic trans this one can be both 350 & 400. i recently got this truck and just got around to check out the pan shape /trans type this afternoon im learning about all the 4x4 options to change here if i keep the truck for awhile, the under carriage & body have 0 rust
Old 06-05-2012, 07:46 AM   #5
andrewmp6
Yeah cheapest over drive 4x4 trans is a 700r4 next step up in price is a 4l60 then the 4l80.
andrewmp6 is offline   Reply With Quote
Old 06-05-2012, 07:59 AM   #6
jjzepplin
jjzepplin's Avatar
Also the bolt pattern on your transfer case will be different from the th350. 6bolts on the 400 and 4 on the 350. Some th400 setups had the 203 case. Not as good as the 205. If you post a pic we can tell you what you have. If you have the 203 you may want to change the whole setup. The 203 has a chain and the 205 is gear to gear. I have a built 700r4 into a 203 ORD splitter and then 205. This has not failed for ten years and two accidents.:-(----
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 06-05-2012, 09:59 AM   #7
SunSoaked
SunSoaked's Avatar
[QUOTE=jjzepplin;5418080]I have a built 700r4 into a 203 ORD splitter and then 205. QUOTE]
What is an ORD splitter? Is it similar to the Ranger splitter or Gear Vendors?
SunSoaked is offline   Reply With Quote
Old 06-06-2012, 07:43 AM   #8
jjzepplin
jjzepplin's Avatar
Off Road Design. They make a kit that uses the gear section of the 203 case and mounts it to the front the 205 case so it gives you another low gear for crawling. With the 700r4 you have to get a output shaft that has the th350 spline. Then you have overdrives and underdrives. WOO HOO! And you can still burn 36" tires! Expensive though.
