Old 06-04-2012, 08:13 PM   #1
JHT67
JHT67's Avatar
suspension swap, whats better?
I have complete donor suspension to do this, 67' 8 lug to 72' 5 lug. What I'm wondering is should I swap out complete crossmember with suspension or just spindles and other necessary parts? I'd like to do what's best, but if there is really no difference then whats easier and faster is the route I'd like to take.
Thanks for any advice on this.
Going through life's daily grind, I can feel the effects of this physical body's fleeting days, But with a young spirit I look toward a brighter day, knowing that in the eyes of eternity, I am but a babe in the arms of my Lord.........
JHT67 is offline   Reply With Quote
Old 06-05-2012, 07:24 AM   #2
68Stepbed
68Stepbed's Avatar
Re: suspension swap, whats better?
Ask Mark or Stan at ECE. Either of them should be able to answer your question. Also, they have the highest quality components and the best customer service.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 06-05-2012, 01:16 PM   #3
gcburdic
Restoration Virgin!
gcburdic's Avatar
I think I would just swap the x-member seems easy enough, but I'm sure the suspension gurus will chime in shortly!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 06-07-2012, 10:47 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Is the motor out, or do you need to pull it? That is really the big difference in what works best. If the motor is out, or your going to pull it anyway, then its pretty simple to swap the entire crossmember.
If you have no reason to pull the motor, it can be lifted to do the conversion, but requires more effort. If thats the case then your better off just swapping parts and leave the original crossmember in place.
Cosmetics are another thing to consider. If your planning to clean and paint everything, it might be to your advantage to swap it as a unit. I have painted a crossmember while it was in place, but it wasn't easy.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-07-2012, 06:21 PM   #5
starvinartis
I agree with N2TRUX, but I would also check for the little bracket where the steel brake line meets the rubber line to caliper. Seems like there's a difference there but cant recall for sure, all my current conversions have the entire crossmember changed out. Also being a C-20, the 1/2 ton spindles may fit the larger ball joints on there, saving having to swap lower control arms.
starvinartis is offline   Reply With Quote
Old 06-08-2012, 05:43 PM   #6
mMad Dawg
I've been checking out pretty much the same thing. I have a 69 3/4 ton that I'm thinking of changing to 1/2 ton. You need to change the bottom A-arm because the ball joint is bigger. The cross shaft bolts on the 3/4 takes 9/16 bolts ,the 1/2 uses 1/2 in. So I suggest put the 72 upper balljoint in the 3/4 upper arm,use the72 lower arm as is with the 72 spindles. If you have the 72 tie rods etc use it all with the idler arm and pitman arm.Hope this helps Gord
mMad Dawg is offline   Reply With Quote
Old 06-08-2012, 05:46 PM   #7
mMad Dawg
Forgot to say,if you are going with dropped spindles use 73-87 upper balljoints asthe 71-72 uppers are different. The71-87 lowers are the same.
