Old 06-04-2012, 09:56 PM   #1
Harley1650
1963 C-10 BBC/Muncie 4 spd
Harley1650's Avatar
rear end ratio question
My 63 has a 454 with a Muncie (M20 I think). My rear end is way too low for my liking. It sucks on the freeway and sucks the gas!. Theres a stock rear end on Craigslist from a 66' SWB 6 cylinder 3 speed. He says its a 12 bolt. The guy said he thinks it should be a 373 gear due to the 6 cyl 3 speed. Can anyone confirm this? I'm actually looking for a taller gear, maybe a 273
Harley1650 is offline   Reply With Quote
Old 06-04-2012, 10:04 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: rear end ratio question
You will have to open the cover and count teeth and do some math. The ring gear should be have some # punched on it and then just count the teeth on the pinion gear and divide. Like the rear end I bought. The ring gear as 43 teeth and the pinon has 14. Divide those # and you get 3.07428571428571428571 and so on. Basically 3.08 gears which will be high enough depending on how tall your tires are. 2.73 gears usually run in cars but they have smaller tires.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-04-2012, 10:44 PM   #3
Narxoleptic Customs
In my rear is a 3.90 set. It was a inline 6/ 3 spd truck...
Narxoleptic Customs is offline   Reply With Quote
Old 06-05-2012, 12:36 AM   #4
Captainfab
60-66 Nut
I've seen some 6 cyl trucks with 4.10's. I agree on pulling the cover and have a look. IMO with a Muncie 4 speed's relatively high 1st gear, I wouldn't go mich higher than 3.42's, preferably 3.73's. If you go to a higher gear, your rpms will decrease, but it will also be more difficult on take off, and you will be slipping the clutch more to get going. Of course this also depends on the diameter of the rear tires you are running.
Old 06-05-2012, 08:00 AM   #5
Harley1650
Harley1650's Avatar
Thats a good point
Old 06-06-2012, 07:59 PM   #6
66 lwb cs
66 lwb cs's Avatar
Another method to sort of eye ball what you have it the pumkin is to jack up the rear end and release the E brake make a chalk mark on the drive shaft and on the pumking then spin wheel one rotation while counting the number of times the mark on the drive shaft goes around past the mark on the pumkin. It won't be exact but as you can guess just over 4 rotations would be 4:10 and just under 4 rotations would be 3:90-3:73 and so on. If you're just looking for a base line with out pulling the cover and all that it's a good way to generally figure out if you have something steep in there like 5:14's or something lower like 2:73's without the mess of dealing with the diff cover. Hope this helps even during your search for a replacement this can be used when someone doesn't know what's in the diff they're selling off Craigs or something like that. Best of luck.
66 C20 LWB CS 327/TH400 A/C
66 lwb cs is offline   Reply With Quote
Old 06-06-2012, 08:56 PM   #7
SIXOSLED
SIXOSLED's Avatar
That does work I did that to one of my old trucks. Except I marked my tire too. I had 3:73 gears, 3 3/4 revolutions of the driveshaft to 1 revolution of the tire.
60 APACHE SWB
SIXOSLED is offline   Reply With Quote
Old 06-06-2012, 10:37 PM   #8
Harley1650
Harley1650's Avatar
That sounds good. I will do that so at least I'll have an idea what I have. Thanks
Old 06-07-2012, 12:43 AM   #9
mikie 1954
MY truck is a 3/4 ton gmc and I had 353 gears put in it, it has a 350 sbc and sm420. It is alot more driveable now and has no problem starting off.If he has a 454 his should handle taller gears with on problem.
mikie 1954 is offline   Reply With Quote
Old 06-07-2012, 03:43 AM   #10
tatanka
tatanka's Avatar
hello
j have the same problem with a 350 engine th350 box the engine is running too fast to bridge what to put as original ratio? chevrolet c10 1966
tatanka is offline   Reply With Quote
Old 06-07-2012, 11:03 AM   #11
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
you could have the best of both worlds and drop in a TKO 600 trans. I run the .64 OD version.
3.90 rear gear great low end acceleration and still cruise the hwy at 2300 rpms.
GMR-PERFORMANCE is offline   Reply With Quote
Old 06-07-2012, 04:25 PM   #12
cruznfb
cruznfb's Avatar
just tryed this trick with my truck ....only got a little over 2 full turns. running 350/350 trans 12 bolt......truck to slow on the freeway with high rpm. i guess i need a rebuild or a new rear end. thanks for the info.
cruznfb is offline   Reply With Quote
Old 06-07-2012, 06:22 PM   #13
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Pull the cover. You will find number stamped on the ring gear and the year it was made for additional info. I tried the tire rotation vs. driveshaft rotation and came up with a different number. I had a 3.08.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 06-07-2012, 11:53 PM   #14
Captainfab
60-66 Nut
A 3.07 gear change would be a good choice in the original 12 bolt differential. Also a larger diameter rear tire will help if your current tires are somewhat small.
Originally Posted by tatanka View Post
hello
Old 06-07-2012, 11:55 PM   #15
Captainfab
60-66 Nut
Did you do this with both wheels off the ground, with an open differential? If so, then you need to turn the tire 2 turns to find the correct gear ratio. It sounds to me like you probably have 4.10 gears.
Old 06-11-2012, 01:27 PM   #16
Harley1650
Harley1650's Avatar
Well, a nice little tag on my rear end says its a 3.54. Now I'm really bummed because I'm thinking the Muncie 4th gear isnt right for my liking. Do you think I'd gain anything going to a 3.08 or should I concern myself with possibly a transmission
Old 06-11-2012, 04:02 PM   #17
Captainfab
60-66 Nut
I think you would gain more of a rpm drop going to an OD trans. However an OD trans that will hold up behind a big block isn't going to be cheap. A 3.07 gear change would likely be less $$, but I don't know how it would be with the tall 1st gear of a Muncie.
Old 06-11-2012, 04:18 PM   #18
Harley1650
Harley1650's Avatar
Im actually considering switching to a 700R4. The 454 is essentially stock so its not big horsepower
Old 06-11-2012, 05:04 PM   #19
cruznfb
cruznfb's Avatar
yep....your right. I have 4:10 gears and just got a quote for $1000 for gear change and rebuild. sounds a little high but will still check for other options.
was told to go to 3:08 gears??? does this sound right? Any other ideas to do this cheaper??
Old 06-11-2012, 10:02 PM   #20
cruznfb
cruznfb's Avatar
question for captainfab...if i bought a whole rear end with non posi 3:08 gears 12 bolt....can i take the everything and just switch into my rear end housing. carrage and all ....add new bearing of corse.. ??
Old 06-11-2012, 10:35 PM   #21
Captainfab
60-66 Nut
Yes, as long as both differentials are truck 12 bolts, and one of them is not a '63 or '64 truck 12 bolt. The '63 and '64 12 bolts originally had 17 spline axles. The '65 and up had 30 spline. But the gear pattern will still have to be checked to be sure it is correct. Swapping used gears is a gamble. Sometimes they setup okay, other times they tend to howl. What about changing the complete rear end?
Old 06-12-2012, 12:39 PM   #22
cruznfb
cruznfb's Avatar
captainfab....yes i thought about the entire rear end but... i had a drive line made to fit and brakes are all new. the axle is 5 on 5 and all my air ride is welded to it. i guess its still a learning cruve for me. i did find a early 80 rear end with 3:08 gear set up but not sure if it a truck rear end. i just wanted to change out the entire center.or i might have to save to get it done in a shop. thanks for the info.
Old 06-12-2012, 01:00 PM   #23
Lauppster
I switched my 3:73 out to a 3:08 posi. Bought all the parts at www.drivetrain.com; they were very helpful and gave a discount for a "complete" package. Found a local guy to assemble and set the new gears for a few bucks. Still cost $800 but that included almost $400 for the posi unit. For what it's worth.
The truck is not on the road yet so I can not comment on the gear ratio and driveablity yet. I did not worry about the ratio for starting from a stop because the 3 speed 1st ratio was so bad with the 3:73 you had to shift at 10mph; not even possible to get across the intersection without shifting.
Lauppster is offline   Reply With Quote
Old 06-12-2012, 08:23 PM   #24
cruznfb
cruznfb's Avatar
wow... thats good to know..thanks for the info...my auto 350 shifts fast also. still ok around town, but wasting lots of gas...cant wait till i someday get new gears. i have to weigh out all my information.
