Old 06-04-2012, 10:00 PM   #1
Frijolito1988
Difference between 68 C/10 1/2 ton and 3/4 ton ?
Hey guys, what is the difference between these two ? Just different gear ratio and lugs ?
Frijolito1988 is offline   Reply With Quote
Old 06-04-2012, 10:46 PM   #2
Frijolito1988
Re: Difference between 68 C/10 1/2 ton and 3/4 ton ?
I just saw a 68 shortbed , 6 lug. Vin says its 3/4 ton. Can this still be a C10 ? Or is it now a C20 ? If its 3/4 shouldent it be C/20 with 8 lugs ? And are all 3/4 ton C20 long bed ?
Old 06-04-2012, 10:59 PM   #3
Shyguy
Junior Member
Shyguy's Avatar
All C-20s are long beds.
There are quite a few differences between a C-10 and a C-20 in suspension, running gear and differentials.
C-20s have heavier springs, larger steering gear, heavier duty brakes, a re-enforced trailing arms and extra braces at the cross member that the trailing arms hook to and thicker rear cab mounts to name some of the differences.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 06-04-2012, 11:07 PM   #4
Frijolito1988
Thanks! So more than likely this is a c10 shortbed , with a c20 cab. Thanks!!
Old 06-05-2012, 06:26 AM   #5
Yes,or a shortened C/20 swapped over to 6-lug.
