Old 06-05-2012, 01:18 AM   #1
sxtrail2
Porterbuilt Body Drop ????
I saw Porterbuilt has body drops.Has anyone bought and installed one?? How is it? Would you Do it again?? I want to lower my 69' about 1 more inch all the way around.It all ready sits 4.5 in front and 6 in rear on coil and drop spindles..Should i go this route or not??Does anyone have any pics?? O yea how was the install??
sxtrail2 is offline   Reply With Quote
Old 06-05-2012, 04:41 PM   #2
67cheby
67cheby
67cheby's Avatar
Re: Porterbuilt Body Drop ????
I got it ....i Love the way it takes it on down !! PINCH FLAT ON THE GROUND , here are a few pics , any questions just give me a shout ! First getting rid of the stock mounts, and adding the new ones
67cheby is offline   Reply With Quote
Old 06-05-2012, 04:45 PM   #3
67cheby
67cheby
67cheby's Avatar
next ! notching the core support
Old 06-05-2012, 04:48 PM   #4
67cheby
67cheby
67cheby's Avatar
next....PINCH ON THE GROUND....and oh, dont forget SLOSH TUBZ !
Old 06-05-2012, 10:00 PM   #5
broey
Square
broey's Avatar
nacho used one too. came out killer!
Squarebody Syndicate
broey is offline   Reply With Quote
Old 06-05-2012, 10:01 PM   #6
1972BackInBlackC10
1972BackInBlackC10's Avatar
nice kit
1972BackInBlackC10 is offline   Reply With Quote
Old 06-05-2012, 10:08 PM   #7
19seventeeCustom
oh man, that looks killer......if only I could pull this off while the truck is blown apart
for the LS1 swap lol
19seventeeCustom is offline   Reply With Quote
Old 06-06-2012, 12:14 PM   #8
502ms
502ms's Avatar
this is hot
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 06-10-2012, 01:38 AM   #9
ddubbs
ddubbs's Avatar
If the truck is apart the kit is very simple to install. It didn't take me long to install on a bare frame. Well worth te money!!!!
LIFTED OR LOW THE ONLY WAY TO GO!!!!
Check out my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=517346
Projects
56 Chevy pickup Porterbuilt FR/RR dropmembers
ddubbs is offline   Reply With Quote
Old 06-10-2012, 07:41 PM   #10
Jimbabwe
Jimbabwe's Avatar
67cheby; with all the other work you did to the suspension, did you need the body drop to fully lay out, or did you do it because maybe it will leave somethin' extra, not fully use the available drop without it. Plus it's kool.
I ask because I'm using Nate's dropmembers front and rear on my step, which is harder to lay out from what I hear. Just curious.
If this doesn't make sense it may be because I've had a few margaritas while out in the garage and I make 'em strong!
Jimbabwe is offline   Reply With Quote
Old 06-10-2012, 07:42 PM   #11
Jimbabwe
Jimbabwe's Avatar
I love Broey's tag line.
Old 06-10-2012, 08:31 PM   #12
67cheby
67cheby
67cheby's Avatar
With just the dropmember your pinch welds are 3/4 inch off of the ground, it give you that last little bit to lay pinch weld !
Old 06-10-2012, 08:41 PM   #13
1972BackInBlackC10
any pics or info on the box mounts? my truck just has the coils and was wanting to lower it some more but didnt want to change the suspension, plus the roads here are crap so i was thinking about this set up since im down to a bare frame right now
Old 05-01-2013, 01:56 PM   #14
70c10longbed
I seen that you notched the core support, I also read that you have to notch the cab for the trailing arm crossmember and notch something at the front of the cab as well. Did you need to notch any of these areas? This is using porterbuilt dropmembers.
70c10longbed is offline   Reply With Quote
Old 05-01-2013, 02:38 PM   #15
PBFAB.COM
PBFAB.COM's Avatar
You will have to notch the following places:
Core support (so it can set over the frame that extra 3/4")
Cab at firewall to to floor pinch weld (really simple and not too involved)
Cab floor for trailing arm xmember (more involved not terribly difficult)
That's all the notching.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 05-01-2013, 02:39 PM   #16
ddubbs
ddubbs's Avatar
On mine I had to notch the floor for the trailing arm crossmember. On the front of the cab I had to cut the pinch weld just above the transmission because it won't let the cab come down to the cab mounts. The core support I haven't done yet but when I looked at it I figured I would have to notch it 3/4" plus what ever the thickness if your metal. The other thing that you will have to do is run a high hump trans cover and modify it for the 1" also. Hope this helps out.
Projects
Old 05-01-2013, 02:50 PM   #17
70c10longbed
Do you have any pictures of the cab floor for the trailing arm x member? The way I'm reading it is that the cab floor needs to be notched the entire section of the trailing arm x member, is this correct?
Old 05-02-2013, 12:19 AM   #18
Narxoleptic Customs
How much is the kit?
Narxoleptic Customs is offline   Reply With Quote
Old 05-02-2013, 12:21 AM   #19
PBFAB.COM
PBFAB.COM's Avatar
$650 for the complete kit.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 05-05-2013, 08:34 PM   #20
bguild
bguild's Avatar
This is not low enough...
KIDDING..
I will be buying this kit for mine.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074
Toys:
2014 Dodge Ram
1967 SHORTBED
bguild is offline   Reply With Quote
Old 05-05-2013, 08:39 PM   #21
bguild
bguild's Avatar
67cheby.... Do your slosh tubz bolt up to all the factory mounting locations? It looked as if you have to trim your fenders.. Let me know because i might buy a set.. Are you going to be at GoodGuys in KC?
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 05-05-2013, 08:41 PM   #22
bguild
bguild's Avatar
Okay I guess there isnt a goodguys Kansas City this year.. Maybe the Des Moines Good guys
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 05-06-2013, 09:51 AM   #23
ulakovic22
What part of the trailing arm cross member causes the interference? Is it the whole width of the x-member that you have to notch the floor or is it just the center section? Is there any design modification to the x-member that could be done to alleviate the interference?
ulakovic22 is offline   Reply With Quote
Old 05-08-2013, 01:58 PM   #24
70c10longbed
X2. I would like to know this info as well.
Old 05-08-2013, 02:04 PM   #25
PBFAB.COM
PBFAB.COM's Avatar
I don't think I took a pic of the notch... at least I can't find a pic yet! The "v" on the upper tube of the trailing arm x-member pokes into the cab about an inch. The length of the notch was about 12" wide. I made it a little bigger than it needed to be.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
