who makes a functional cowl hood
all the ones I see at home here are not functional,do I have to go to fibreglass ?
Re: who makes a functional cowl hood
goodmark
officer,we weren't racing.. he was merely pacing me. |
Harwood. I have a 4 inch. It has some structure with a screen in the back of the cowl.
2016 GMC Sierra Double Cab 1986 GMC Sierra Classic SWB 1972 Chevy Cheyenne C20 4x4 Camper Special |
![]() Join Date: Sep 2010
x2 i have the same hood but i think mine is 3". Awesome fit and great quality
1985 c10 355 th350 (working on 4 speed conversion to super t10) 1979 camaro 358 super t10 2003 f250 superchip slp exhaust |
Parts and more parts
I have an older Harwood fiberglass hood and I like it very much. It weighs about 1/3 of the the original hood.
Frank |
x2...fully functional and steel unless your looking for a flapper door induction style then your SOL on all accounts
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
The One And Only !!!
Sooo, This hood has the inner structure to seal on top of a cowl air filter assembly ?
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
NO, it does not. It will have the usual bracing under it to give the hood strength, just like any metal GM hood. At least the ones that I have seen from Goodmark did.
Frank |
#9 | |
Thanks Frank, I've yet to see/find a steel or glass that was "Fully Functional".....
In the Forgotten far North.
![]() Join Date: Jul 2007
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
I've never seen any that are functional.
I added my own sheet metal to the underside of the steel aftermarket cowl induction hood that I bought for my '76 Camaro. It fits fairly tight over the top of a triangular, 1000cfm Edelbrock air cleaner (available from Summit Racing) and provides a functional cowl induction. That may be a possibility for you. I hope to dual RAM air to FRANKENTRUCK in the future. I don't think it needs it though,... Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK! |
none of them are, I thought you just wanted one that was vented/open to pass air thru
#13 |
#14 |
You are going to have to do what BLE BURB is doing and build one, if you want it to seal to the top of an air cleaner. My open cowl hood does provide a negative pressure at the opening, I have proof of that. The air is going into the engine bay and since I run a K&N 14" X 4" tall air cleaner that has the "Extreme" top plate that has the filter media on it, I am getting a good air charge to my carb. My hood does not seal to the air cleaner, but it does work as indicated by the dirt collection on my oil media in the filter.
Frank |
