Tops
I have a double wall that's in pretty good shape but has a few spots I would like to get it redone. Is there any suggestions on who could do it or is there a place to buy new ones
Posted via Mobile Device |
Re: Tops
I found a guy that used to do fiberglass repair on boats. Depending on what needs to be done you could probably have a fiberglass guy do it fairly reasonable. You might also check into a RV repair shop they also do fiberglass work. Whatever you choose to do make sure the person doing the repairs uses resin and very little bondo if any.
Re: Tops
thanks for the info
