t56-electronic speedo help
ive posted this in engine and drivetrain to no avail- so im here for some attention- i have a t56 from a 93 trans am i am wondering if i run this on my old small block non computerized if theres a simple way for me to get my speedo to work can i take an electronic speedo and wire it in directly somehow or does it need to go through a pcm or cpu? what are my options here??
Re: t56-electronic speedo help
ttt for some help
http://www.atrol.com/cablex.htm
Vss converter, it'll set ya back 300 and some change, but that is the waist way I've found. Posted via Mobile Device
74 C10 LWB 350/T5 Dropped on 20's Soon to be Bagged and Injected 84 C35 Crew Cab Dually. 454/400 Dropped a lot. Instagram: mmmdropp |
Get a speedo out of a 90-91 suburban or dually and wire it up or could do the camaro gauge swap in the late 80,s they went to elec speedo I belive
Posted via Mobile Device |
agreed on the elec speedo and ive thought of the camaro swap too but can i just wire the speed sensor to the speedo or do i need to go through something else too, seems to me like i need to go through a pcm or some thing else to convert the signal? does anyone have detailed info on this? i think its called a DRAC module?
