Old 06-06-2012, 01:54 AM   #1
forverfate
forverfate's Avatar
66 Chevy truck backfiring
Does anybody have an idea why my 66 c10 would be backfiring only at 2500 rpms and above ? Timing off ? Possible fuel fuel getting colged ? Could it be ****ty gas ? I have recently put new edelbrock air gap manifold and new edelbrock 1406 carb , new fuel filter . Any suggestions would help .
forverfate is offline   Reply With Quote
Old 06-06-2012, 01:57 AM   #2
joedoh
joedoh's Avatar
Re: 66 Chevy truck backfiring
under load/accel only? vacuum leak or lean mixture or both.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 06-06-2012, 01:58 AM   #3
forverfate
forverfate's Avatar
Accel only .
Old 06-06-2012, 07:47 AM   #4
hugger6933
check the firing order may be cross wired look for vac leaks with some carb cleaner with the engine runnig if you spray at the motor the it changes tune then you found your leak. plug wires canbreak down as cause the under load miss as well
hugger6933 is offline   Reply With Quote
Old 06-06-2012, 08:22 AM   #5
joedoh
joedoh's Avatar
I have seen a lot of newly installed carbs where they get cranked down too tight and it causes a vacuum leak at the base. also, make sure you have plugged all open vacuum ports on the new intake and carb.
Old 06-06-2012, 08:41 AM   #6
awbrown
did the problem start the same day you installed the intake and carb????
awbrown is offline   Reply With Quote
Old 06-12-2012, 05:03 PM   #7
forverfate
forverfate's Avatar
Thanks everybody for the help ! It was my plug wires . One got burnt all the way to the metal . Should checked that first .
Old 06-12-2012, 05:14 PM   #8
forverfate
forverfate's Avatar
What hei disturbtor is the best for my truck ?
So I am looking for a new Hei for my 66 and I have a 350 v8 . Looking for some input before I buy one. Room is tight and was going to get a small cap or skinnier one. I have no idea about this. I am not going the cheap route , and would like an American made one ,if possible !
Old 06-12-2012, 05:53 PM   #9
jchav62
1962 C-10
jchav62's Avatar
I've run regular GM HEI distributors on these trucks. I have HEI in my '62 and the '65 also had HEI until recently. Converted that one the TBI and used the newer distributor.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-12-2012, 06:22 PM   #10
TopFuel1966
TopFuel1966's Avatar
Re: What hei disturbtor is the best for my truck ?
That would be spelled MSD
TopFuel1966 is offline   Reply With Quote
Old 06-12-2012, 07:42 PM   #11
gimmy 64
MSD streetfire resonably priced and works great. you don't need a polished billet distrubtor because you can't see it anyway lol. when you install it put dist.in first and then put cap on it will fit fine.
gimmy 64 is offline   Reply With Quote
