06-06-2012, 10:42 AM | #1 |
Posi rearend question
I have a 69 12 bolt that I am going to be putting new bearings and seals in. I figured why I'm in there I might as well put an Eaton posi in. I will be running a 275/60/15 tire in the rear and a 350th with a 5000 stall converter. The truck originally had a 250 6cyl and manual 3spd with 225/70/15 tire in the rear
My question is what gear should I run for highway/street use. This truck is a weekend warrior that will be driven to shows. |
06-06-2012, 11:08 AM | #2 | |
Re: Posi rearend question
http://youtu.be/npwEOmpPC4s Last edited by hjewell2; 06-06-2012 at 11:10 AM. Reason: change |
06-06-2012, 12:31 PM | #3 |
I'm not sure I want to do 4:11 for street or highway use. I was thinking 3:73 or lower.. This truck will probably never see a drag strip.
06-06-2012, 12:34 PM | #4 |
Why such a high stall if your just running on the street and highway. Just asking.
If you can't impress them with your inteligence, dazzle'm with your stupidity 1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe |
06-06-2012, 12:46 PM | #5 |
I didn't put the motor/trans together (not really my strong point) I'm told that what was put in it.. I may be wrong. I will ask about it.
06-06-2012, 12:51 PM | #6 |
Ya I'm no tranny expert either haha but a 5000 is pretty tall I think. It would probably cook it self on long highway drives. Maybe I'm wrong but just from what I read it seems to make sense.
06-06-2012, 01:46 PM | #7 |
LOL!! OMG!! My stall number was way off!!! I just called the guys that built my trans, 1800-2200 stall. I discussed what gears I should run and it was agreed that a 3:55 would probably be best for street/highway use with a 275/60/15
06-06-2012, 02:30 PM | #8 |
3.55 would rock, i have 3.73 with a TH400 and love it but if you do any amount of highway 3.55 would be great.
What gears do you have now? If im not way off I think the 250 6cyl had 3.73 or 4.11 originaly?
69 c10 lwb |
06-06-2012, 02:40 PM | #9 | |
http://www.wallaceracing.com/Calculators.htm |
06-06-2012, 03:00 PM | #10 |
Wow.. So I just looked up an Eaton posi, 3:55 ring and pinion, and install kit and it came to over $800 through Summit Racing. Anyone know of anything cheaper..
However, I just found a complete kit on Ebay for $645 with free shipping Last edited by Rochlow; 06-06-2012 at 03:20 PM. |
06-06-2012, 03:13 PM | #11 |
Im running TH400, 411 posi and 3000 stall hughs converter I love it. I want to install A 700R4 but in time. Not A daily driver.
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" |
06-06-2012, 03:24 PM | #12 |
Moderator
Make sure they are quality gears (like Richmond), or else your rear end will howl like a coyote. $800 is about right for decent parts.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
06-06-2012, 03:46 PM | #13 |
I run the same size tire and about the same stall with a 3.73 gear and a 700r4. In OD with the converter locked it runs 1500-1800 rpm. I'll see what it runs in third next time I'm on the highway. A 3.73 should keep your cruising RPM up above or close to your stall rpm but it's a matter of preference.
06-06-2012, 03:49 PM | #14 | |
This is the one I was thinking about. I'm going to research a bit more before I make the leap. Thanks for all the help guys, Greatly apperciated. Last edited by Rochlow; 06-06-2012 at 03:58 PM. |
06-06-2012, 04:53 PM | #15 |
I bought my 3.73 eaton posi off ebay from this guy
Brydon R. Papenberg <staticz2229@gmail.com> Great service from him and his company. I think if you look up his email up on ebay
69 c10 lwb |
06-06-2012, 06:28 PM | #16 |
