Remove vent window and window
How do I remove my vent window and regular window and seals for Paint?
Posted via Mobile Device |
Moderator
![]() Join Date: May 2007
Re: Remove vent window and window
Here you go: http://67-72chevytrucks.com/vboard/s...d.php?t=153937
http://67-72chevytrucks.com/vboard/s...d.php?t=178040
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
![]() Join Date: Oct 2011
Took me about 45 min per door. After you remove crank and door lever. Remove door pannel. Roll window down till slot's in the regulater line up with window metal. Remove window by lifting out. I removed the felts at the door edge at the last minute before the glass came out to protect the glass. Take notes and your time. The rest is ez. Tip the vent window to the rear of the door when you remove it. I am not to far from you if you get stuck.
