Filler Neck Locations:
I am relocating the tank to under the bed and want to see where folks put their filler necks. I'e got a 64 short stepper and I don't want to do the in the bed Boat Filler Neck. Anybody have photos of other options such as fender mounts. Thanks.
Re: Filler Neck Locations:
http://67-72chevytrucks.com/vboard/s...d.php?t=248460
i think alan put one in the bedside. youll have to look in his thread for it, but it was super clean.
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726 ![]() 66 fleet lwb- In process 64 k10 10inch lift 38.5's- In process 92k1500 400hp on 38.5-parts truck now 8( |
Senior Enthusiast
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
![]() Join Date: Aug 2011
A friend of mine has a 64 step just like mine.
He re-located his tank to under the bed and brought the filler neck out the side of the rear fender behind the back wheel. He picked up a gas cap door from a wrecking yard, cut it and welded it in place on his rear fender and it looks great. Sorry I don't have pictures of it to post. You can buy about any shape and style fuel door you want, his happens to be a small rectangular one. Being it is a STEPSIDE you don't have the options these guys with fleetsides have.
http://s994.photobucket.com/albums/af62/ScottAz2/ Last edited by McCoyAZ; 06-06-2012 at 04:02 PM. |
![]() Join Date: Mar 2010
Put mine inside the bed with an electric door on the filler.
Works great and I don't have that marine filler sticking through the bed. regards
65 burb On the road Mar 26th Finally |
Behind the license plate. Used a Camaro tank under the bed
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201 no garage, no shop, limited storage space and tools....no problem. |
![]() Join Date: Oct 2009
I like THAT approach the best personally (behind plate)
k1 - how many gal is the Camaro tank? |
18. Same As stock. Only downside is ther sender is 0-90 ohm. Add a resistor or a pot and you can get it to work switch our stock gauge. It wont be linear, but from experience I know our gauges aren't the most accurate anyways
Senior Car Nut
![]() Join Date: Jan 2008
I, too, like the rear fill tank idea. my donor truck came with one although I don't know what the tank came out of (I'm not sure it was even GM). I've been looking for something else. Here's a good source to use to check out tank dimensions: for instance dimensions on the '69 camaro tank:
http://www.gastanks.com/1969-Camaro-...ctinfo/GM-32B/
Larry |
I should have asked for these ideas before getting the Blazer tank since I do like the rear filler tank idea. So I will be doing something out the side and mounting the filler on the fender.
My how to is posted under the sticky. If the pics don't work I will have to go back and fix the links
#13 |
This is where I just recently changed mine to.
#14 |
I have my tank under the bed and my filler neck on the driver's side fender. Sorry about the crappy cell phone pics.
1964 Chevrolet C10 SWB Stepside (350cid/TH400) 1978 Chevrolet C10 SWB Silverado Big 10 (454cid/TH400) -"Ah, the pressure's fierce!" |
#15 |
Johnny:
What was the filler door off of that you used for you truck?
http://s994.photobucket.com/albums/af62/ScottAz2/ |
#16 |
Sorry McCoy, I'm not really sure. I got it from a buddy who had several he had collected from junk yards over the years. He thinks it may have come off of an older (late 80's or early 90's) Toyota Camry but he's not positive. It's smaller than the one I had originally planned to use off of a mid '80's Chevy fleetside, which was too wide for the top of the fender on my '64 step.
#17 |
Johnny, thanks for the photos. Do you have any photos of the underside and what type of hoses did did you use?
