Old 06-06-2012, 06:45 PM   #1
jimig1
jimig1's Avatar
Ignition switch question V8 Vs straight 6
What is the difference in a V8 Vs straight 6 ignition switch. I have been searching for the answer but have yet to find it.
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
Old 06-06-2012, 07:58 PM   #2
G&R's57GMC
G&R's57GMC's Avatar
Re: Ignition switch question V8 Vs straight 6
The V-8 has a crank position, the 6 uses a button on the floor to engage the starter.
G&R's57GMC is offline   Reply With Quote
Old 06-06-2012, 09:39 PM   #3
NW Task Force
NW Task Force's Avatar
Question Re: Ignition switch question V8 Vs straight 6
I was wondering if you can buy a V8 ignition switch and directly plug it into the factory harness plug? Are the ignition plugs totally different or can you make a 6 cylinder ignition work with the V8 switch? I am planning on using my stock harness (6 cylinder) and putting in a V8 engine. How will this work?
1957 Chevy Pickup 1/2T, stepside, big window, 77' Camaro subframe, 3rd gen Firebird rearend w/3.23 gears & disc brakes, 66' 283cid, TH350 auto, everything else is original
NW Task Force is offline   Reply With Quote
Old 06-06-2012, 11:32 PM   #4
jimig1
jimig1's Avatar
Thanks for the info. My truck had a 6 cylinder but there were 3 ignition switches that the PO had in a box of stuff. Only 1 of them was for the truck and was not sure what one i had but it looks like I have the V8 Switch. Thanks
MSRA Member
-George Carlin
Old 06-07-2012, 01:39 AM   #5
G&R's57GMC
G&R's57GMC's Avatar
Nope, you'll have to add a push button start switch.
Feed power to it from the run position then down to the solenoid on the starter.
This way you can't crank the engine with the key off.
Old 06-07-2012, 11:40 AM   #6
mr48chev
mr48chev's Avatar
You can also run an extra wire from the "start" pole on the switch to the solenoid.
As the truck won't have a neutral or clutch safety switch I'd consider putting a pushbutton in the wire from the switch so that you had to use both hands to start the truck. Turn the key with the right and push the button with the left at the same time.
With the pushbutton hidden under the lip of the dash but in easy reach it becomes a natural move. It helps keep unauthorized people and or kids or grand kids from starting the truck too.
mr48chev is online now   Reply With Quote
Old 06-07-2012, 09:12 PM   #7
Root2812
Root2812's Avatar
Please reconsider this. A new harness is a few hundered bucks and a weekend to install. Its alot easyer than rebuilding your truck after it burns to the ground. Sadly, far to often I hear about peoples projects burning up because they ignored the 50-60 year old wireing.
Root2812 is offline   Reply With Quote
Old 06-07-2012, 09:44 PM   #8
1project2many
Hydromatic equipped 6's used the off-run-crank type switch as well.
If your truck is one of the ones that didn't have a fuse panel, it's far safer to replace the wiring than to re-use it. The wiring is not too complicated and a careful person could build a harness fairly inexpensively. If you're planning to do any customizing it's better to have the harness built after the truck's done anyway to minimize wasted work.
1project2many is offline   Reply With Quote
Old 06-08-2012, 07:38 PM   #9
NW Task Force
Sorry, I left out an important piece of info. The entire truck was re-wired in the early 90's with a Painless Wiring kit. I assume the previous owner purchased the kit that corrisponds to a six cylinder application since that's what the truck had at the time. I wonder if Painless Wiring makes their kits "universal" for both 6 and 8 cylinder equipped trucks?
Old 06-08-2012, 10:31 PM   #10
Root2812
Root2812's Avatar
Ahh in that case proceed.
