Old 06-06-2012, 06:48 PM   #1
f.monroe
f.monroe's Avatar
Billet Specialties Vintec SL Dish pics please
Anyone running BS Vintec Dish wheels in the Soft Lip please post pics . I am looking for pics that show the dish they have and please include the backspacing and tire size specs. looking for pics both front and rear . Right now I think 20x8.5 and 20x10 with 5" backspace each is what it will take on one of our trucks to look right .
Thanks ,
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 06-06-2012, 08:42 PM   #2
Pro Performance
Pro Performance's Avatar
Re: Billet Specialties Vintec SL Dish pics please
Frank,
It is on an older C10, but thought I would share anyways. These are pictures I found on this forum. Not sure who it belongs to, but they are very nice trucks. Might help give you an idea as they take similar backspacing depending on rear axle. The dish does eat up some wheel lip, but the dish has a nice look to it. The red truck has a 5.75" backspace on the front, and the teal one, 5.5" on the front.
On a 73-87 C10, I would run 10" on the rear with 5.5" and a 8.5" up front with 5.25". Hope these pictures help some.
We are a direct authorized dealer for Billet Specialties, so let me know if I can help you out with a set. We just ended a 10% off deal last month, but send me a PM and I will get you some good pricing... no worries.
- Travis
Pro Performance is offline   Reply With Quote
Old 06-06-2012, 10:16 PM   #3
f.monroe
f.monroe's Avatar
Those are super nice trucks. I looked through Lucy's build thread but didn't find the specs on the rear wheels. I may have missed it. Neat thing is that I think both of those are 6 cylinders. Just supr nice trucks with the dish I am looking for on the rear. I think I will go look through the build threads again on both of those.
Thanks,
Frank
Old 06-07-2012, 10:30 AM   #4
Pro Performance
Most likely, they have about a 5.5" backspace on the rear. I believe the earlier one is using a later model rear end, and those truck with the later rear ends, use a 5.5" backspace. Your wheels would be very similar.
Old 06-07-2012, 12:18 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
The teal '69 swb truck belongs to 72BlckButy.
It has the narrower 67-69 rearend.
20x8.5 (5.5" BS) and 20x 10 (4.75" BS).
Keith
Convert to disc brakes.
Old 06-07-2012, 12:56 PM   #6
Pro Performance
Thank you for clarifying! I couldn't remember if I read it have the wider rear or not.
Travis
Old 06-07-2012, 03:04 PM   #7
f.monroe
f.monroe's Avatar
Looking throught the threads I found that the Keiths Red truck is running a 4.75 bs and Nates green truck is running a 4.5 bs. I think I may order the 4.5 bs and find a 67-69 rear axle to build.My Intros had 5.25 bs on the 10's and fit great but the Vintecs dont allow as much lip so I think the extra lip is needed for the look I want. I was mainly curious if anyone had pics of a 20x10 with 5 or 5.25 backspace .
Thanks ,
Frank
Old 06-07-2012, 05:50 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Frank.... actually here are the specs for the wheels on my truck. (Pg 15 on my build thread.
Billet Specialties Vintec's
Front: 20x8.5" w/ 5.5" BS
- Center Bore: 3.430
- Bolt Pattern: 6 on 5.5"
Rear: 20x10" w/ 4.75" BS
- Center Bore: 4.250 (due to the center hub on the rear axle of my '69 [meas. 3.5"; BS only offered 3.43])
Toyo Proxes S/T ii's
Front: 255/40-20
Rear: 295/40-20
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-07-2012, 05:59 PM   #9
f.monroe
f.monroe's Avatar
Thanks Nate.
Any chance you could take a pic of your wheels showing them at an angle. I would like to see the depth of the lips front and rear.
Frank
Old 06-07-2012, 06:09 PM   #10
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I will try to get you a picture tonight buddy.
-Nate
Old 06-07-2012, 09:48 PM   #11
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Here you go Frank... let me know if you need any other pictures. In case you haven't seen Vintecs up close, the spokes curve to the outside unlike TTii's and Coy's which makes the lip appear to be less than TTii's and Coy's.
-Nate
Old 06-07-2012, 10:00 PM   #12
f.monroe
f.monroe's Avatar
Thanks for the pics Nate . That helps . I definitely want vintners with the soft lip and the dish. I just have to decide if I want to build a rear axle and run a deep lip or buy wheels that will fit what I have.
Frank
Old 06-07-2012, 10:09 PM   #13
Pro Performance
You can still get a pretty good lip even with a 5.5" backspace on a 10" wheel, but I agree, a 4.75" would be even better!
Old 06-07-2012, 10:33 PM   #14
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Frank
For me... I wouldn't build a truck that I wouldn't be happy with once I was finished. A rearend is (generally) cheaper than a set of wheels, and wheels can make or break a look.
My $.02... change the rear.
-Nate
Old 06-07-2012, 10:37 PM   #15
f.monroe
f.monroe's Avatar
I think that I am going to try to find a 67-69 12 bolt housing. That would make a 4.5 backspace a perfect fit on the rear. maybe even a 4.25 bs.
Thanks,
Frank
Old 06-07-2012, 11:43 PM   #16
Pro Performance
I agree with Nate, if funds allow, then changing the rear end is a must. Color, stance and wheels are the 3 most important things, in my opinion.
Old 06-08-2012, 10:45 AM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks,
Frank
Thats a lot cheaper than having one narrowed. Thats what I am planning for my 77 "if" I ever get back on it.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-18-2012, 09:47 PM   #18
f.monroe
f.monroe's Avatar
Bought a '68 12 bolt housing from member Lynnfield. Met Greg this weekend on my way back from DFW. He had it out for me , helped me load it ,sold it at a great price ,and even listened to my rambling. He deals mostly with 67-72 parts but if you need a part in the Waco area I would look him up. Thanks again Greg.
Frank
Old 04-26-2014, 08:55 PM   #19
bcnya2
bcnya2's Avatar
Hello.......Im a interested in a set of the SLD 89 for my 72. Im unsure to go with either the 18 or 20 up front, but defin 20 on the rear. can you price them both ways? 18x8.5, 20x10, and 20x8.5, 20x10. Also, how was the red truck lowered? Whats your recomm on offset? Im seeing 5, 5.25,5.5 of front and rear.
thank you,
Greg
Originally Posted by Pro Performance View Post
Frank,
- Travis
72 Cheyenne Super 350 Holley EFI/700R4
67 Camaro SS/RS
68 Corvette 427 Tri-power 4-speed convertible
55 Chevy Belair Hardtop
bcnya2 is offline   Reply With Quote
Old 04-27-2014, 07:36 AM   #20
CHROMAHOLIC
CHROMAHOLIC's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=317834
CHROMAHOLIC is offline   Reply With Quote
Old 04-27-2014, 07:39 AM   #21
CHROMAHOLIC
rear lip
Old 04-27-2014, 12:28 PM   #22
JWall
Frequent Flyer
JWall's Avatar
Originally Posted by bcnya2 View Post
and 20x8.5, 20x10... Im seeing 5, 5.25,5.5 of front and rear
That's what I am running...
- Justin
1 Owner 1976 SWB
