Old 06-06-2012, 08:50 PM   #1
1moretoy
Those with a/c I Ned a little help
Im looking for pics of how low the factory or aftermarket a/c box hangs down inside the cab. I mounted the computer under the cowl right above where the a/c will mount. I'm worried with the computer the and the a/c it might look funny if it Hangs too low. I'm looking at the classic auto air street rod cooler II kit. It only measures
20"long x 7-1/8 wide and 9" high. Thanks
1moretoy is offline   Reply With Quote
Old 06-07-2012, 08:49 PM   #2
1moretoy
Re: Those with a/c I Ned a little help
Anyone?
Old 06-07-2012, 09:50 PM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: Those with a/c I Ned a little help
I have factory AC. Not the best picture though. I can get some tomorrow for you if you like.
I mounted the computer inside the glove box.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 06-08-2012, 06:14 AM   #4
ToddT
ToddT's Avatar
The under hood tag shows what kind of unit it is, hope the pics help
ToddT is offline   Reply With Quote
Old 06-08-2012, 07:20 AM   #5
MARKDTN
If I ever did another one with stock a/c and a computer, I would use the weatherproof computer in the engine compartment. The combination of TPI ECM and factory a/c just ate up the whole glove box. Underdash a/c would be easier to work around.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 06-08-2012, 12:10 PM   #6
biggestjohn
I am planning on mounting my computer behind the gage cluster. There appears to be plenty of room there.
biggestjohn is offline   Reply With Quote
