part interchange?
First off, great site have found alot of usefull info for my new wheels. My truck is lacking a rear bumper and fan shroud if I were to go to a pull-a-part yard what would be some suitable subs. It has stock radiator and a 350.
Thanks for the help. |
Hot Damn - Here I Am!!
I'd venture a guess that a rear bumper off a Chevy/GMC stepside up through '87 would work. I doubt the newer fan shrouds would work though - The radiator is taller on the newer trucks.
Nice truck you got there!! ![]() Robert
My vehicles: '90 Silverado Sport '71 Chevelle SS Convertible '70 C-10 - My Grandfather bought it new - original un-restored Last edited by Roberty; 05-14-2003 at 10:33 PM. |
Welcome to the 67-72 boards.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
67-72 rear bumper chevy or gmc
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
its all about the +6 inches
Welcome to the board.
You need to look up Wes at Classic Heartbeat Pick up Parts. He is located in Olympia, Wash. (is that close to you?) Wes normally has tons of used parts and trucks along with great prices on new stuff too. Here is a link to his site. http://classicheartbeat.com.westserver.net/ He is one of the few that I normally recomend...mostly becouse I have not dealt with many places, but he knows his stuff and treats you right. And that is an awsome looking truck...whats the details on it? |
while we're on the subject will a brake booster and master cylinder off of an 85 pickup work on a 71 pickup?
Thanks for the compliments. The details aren't alot.I bought it a month ago for 4k it has had some work done rebuilt 350/350, guages, 12 bolt rear 3:73 gears newer paint. Have lots of plans but as seems to be a common theme (no money and less time). Maybe when I'm done in the Air Force I'll have time and money to fix it up right!
Lightspeed,
My understanding is that the primary concern with master cylinders is that you need the same configuration of brakes or you'll run into problems. Drum brakes require a great deal more pressure to work than disk, so if you used a drum-rear M/C with disk-rear brakes, you'd have your back brakes locking up way too fast. The opposite would also be true. Brian |
well i have a disc/drum setup on my truck and im guessing that the 85 would be the same. im more concerned about it actually bolting up than anything else.
On the fan shroud, go with the original equipment. Small block ones are available on the parts board on occasion. Don't get in a hurry, you'll be fine without it in Spokane for a couple more months. Problem with finding a pull a part might be bolting it up to the radiator more than anything. Post a request for a shroud to the parts board and someone will likely come the the rescue.
One the booster items, you probably can use the master cylinder and prop valve and be okay. I've seen newer ones used, and it will need to be disc/drum components (don't thing there was any other options in '85, no ABS yet on the rears). I doubt the bracketry will fit nor the brake pedal angles are the same. Most if not all of the original components are still availble from supporting distributors as well as your local parts house. Someone will have a shot cab that you can buy the booster bracket an rod from on this site too I would imagine.
http://home.comcast.net/~r.landrum/w...tos.html-.html '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. |
BTW, awsome looking truck for 4k.
I have two brothers that live in Seattle, thus I have picture of my daughter with clouds very similar to the ones in your picture.
Hey I live here in Spokane and I might have a used fan shroud for you. I will look tomarrow and see what I got.
#13 |
![]() ![]() Join Date: Jul 2002
Welcome to the board from south Mississippi.
#14 |
computer illiterate
welcome from nashville
72 2wd blazer 72 swb 4x4 |
#15 |
Welcome from Southern Washington State..............
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
#16 |
1969 Custom 30 wrecker
For the cost of a new repro bumper, I'd definetly go that route over used. Especially if going with a chrome one.
A truck worth 4K deserves a new bumper! ![]() For the fan shroud, search the junkyards. I found mine that way. I paid $3.00 for it! :p
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
#17 |
![]() Join Date: Apr 2003
welcome from kansas
david
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
#18 |
Almost Satisfied
![]() Join Date: Mar 2002
I have a painted rear step bumber I would sell. Shipping might not be worth it though.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
#19 |
Guest
Posts: n/a
Welcome from So Cal
Benny |
