Two Fuel Tanks???
My Blazer has two fuel tanks (see the round hole just behind the driver door). It has a toggle (I think it's the toggle at least) that switches the tanks installed between the two front seats on the floor.
Was this an option from GM? It looks like it was added later. Anyone know where to buy a larger tank that drops in place without much hassle? |
Just a nother gear head
Re: Two Fuel Tanks???
thats was not an option. totally a po install. i believe the larger burb tanks will fit with out alot of mods.
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 ![]() |
Northwest Metal Products (NMP) makes a 37 gallon tank that replaces the stock unit. I run one in my Blazer. Comes with proper fuel sending unit to keep the stock fuel gauge working right.
Looked on LMC 67-72 seem to only have 21 gal. Do happen to know what year burb fits best? I think I found them... 1973 - 1993? 25, 31 or 40 gal.
$622. Ouch.
1954 Ford F-100 1956 Chevy big window 1970 4x4 Blazer CST 1987 Land Cruiser 1990 Chevy K3500 454 |
cleszkie - are you happy with that NWP tank? it fit up in the undercarriage alright and what not? thinkin about upgrading to a larger tank...especially cause i think the factory one i have has a bunch of gunk in the bottom lol
1972 k/5 Blazer 350V8/TH350/NP205 "The Ox" ![]() |
#7 | |
![]() Join Date: Mar 2010
1972 Chevy K5 Blazer 1972 Chevy K20 1955 Chevy 3100 "If we knew what it was we were doing, it would not be called research, would it?" - Albert Einstein |
Yes, custom is MUCH more than the NMP unit, and it wouldn't be 37 gallons either (at least not the custom ones I've been looking into). I've been digging into this for quite some time now as I want to upgrade my fuel system to an intank pump for the fuel injection with enough to support 600+ hp. Custom tank and fuel system is going to set me back $1500+
The NMP unit is the way to go if you want the extra capacity too. Once you start pricing out the custom stuff, $600 is chump change, and I like the idea of having 37 gallons vs 20-25. Long road trips are the norm for us and fewer stops at the go juice station is nice ![]() |
SKINNY TIRES RULE!
I've got three tanks on mine. The two Hickey side tanks are in the bed behind the rear wheel wells. The fuel feeds from one first then draws from the other. There is a switch to go from the main to the aux.
I don't use the extra tanks. they are basically empty (some fuel sloshing around in them). Being in-city all the time I really don't need that much gas and the fuel gauge doesn't work with the aux. tanks.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
