Old 06-06-2012, 10:21 PM   #1
86c20
86c20's Avatar
Question 6.2 hunting for idea
truck is a 83 6.2 th400 4x4 burb. truck has been setting at least 2-3 years. glow plugs stay on unless unpluged fast ideal seems high and when she kicks off she will hunt and wont smooth out bring it up and runs great. cant do a road test as has no breaks yet also motor is supposed to be rebuilt. could it be the pump is not adjusted right? anythiing will help thanks, mike
86c20 is offline   Reply With Quote
Old 06-07-2012, 12:20 AM   #2
rcbildr
rcbildr's Avatar
Re: 6.2 hunting for idea
IIRC 83 has the old style of glow plug controller. Sounds like it's not working properly, its probably best to wire up a push button control for it....there's a lot of write ups on that. I would dump a can of seafoam in the tank and replace the fuel filters and run it for a bit and see what happens.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 06-07-2012, 01:16 AM   #3
hatzie
Moderator
hatzie's Avatar
Updating to the newer 1990's glow controller is as easy as bypassing the early unit.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-07-2012, 06:36 AM   #4
D13
D13's Avatar
X2. Did this on mine with a F*rd starter relay, mounted it to the left rear intake studs with only a little opening up of its holes (threw away the EFE/EGR when I went to the J code intake), 4 gage feed wire, $5.99 momentary push button under the dash, 6 ft of wire, and boy is it better. Mine is an 87 with the later controller, left the controller in parallel as sort of a timer, when it clicks off I give it another 10 secs of glows (I use 10g slow heat self-limiting glows so need a little more on time). It fired off on the 2nd rev last week, after sitting since October.
The hunting is an injection pump wear problem, sloppy advance. Mine started to do it at low RPM light load, like 35mph on cruise in the city. It got progressively worse until finally I changed out the pump. The cold idle being high, probably all the idles are high because they turned up the idle to try to hide the worn pump hunting problem. The Seafoam may help, and you can drive it with the hunting, but the pulses aren't good for your drive train. Sooner, not later, you'll need a pump.
BTW the next thing you should see is fuel dripping from the advance shaft at the bottom of the pump. A reseal kit is unlikely to fix it, usually it's worn and the pump needs rebuilding.
Welcome to 6.2's, I get 23mpg mixed driving on my fully loaded 87 R10.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
