06-07-2012, 11:06 AM | #1 |
WTB: Column OD indicator
I am looking for an OD column indicator. I will need the housing as well. My is dented somehow??
1956 GMC undergoing LS Swap |
06-07-2012, 11:13 AM | #2 |
VA72C10
Re: WTB: Column OD indicator
is the housing tilt or non-tilt (there is a difference)
Looking for a 67-72 swb or blazer project in or around VA. |
06-07-2012, 02:25 PM | #3 |
I've never seen a non-tilt OD indicator. Do they even make one?
Cheers, |
06-07-2012, 02:46 PM | #4 |
VA72C10
I am pretty sure I've seen them aftermarket that fit in std auto columns...
06-07-2012, 03:36 PM | #5 |
"GO DAWGS"
Contact member KevsClassics, as many of these that he has restored I am sure he could answer this question.
PT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops |
06-07-2012, 03:40 PM | #6 |
Satin69, so is it a tilt or no?
Cheers, Last edited by 72peace; 06-07-2012 at 04:05 PM. |
06-07-2012, 04:10 PM | #7 |
"GO DAWGS"
This is tilt only and at $100.00 it is not very affordable. Here is the link http://www.lmctruck.com/icatalog/cb/full.aspx?Page=97
PT
06-07-2012, 04:17 PM | #8 |
I found a link to this one, the "salesman told me" it's designed to work with the ididit columns but since it uses adhesive to connect to the column you should be able to remove the OEM and install this one.
http://www.ecklerstrucks.com/chevy-t...1947-1972.html Cheers, |
06-07-2012, 05:48 PM | #9 |
Thanks for the help guys. It is indeed a tilt. Screws to the top of the housing.
06-07-2012, 05:51 PM | #10 |
If it is going to be that much, I might as well go for a Lokar... Jonathan, do you happen to have one?
BTW- You are welcome to use me as a reference on your dashes any time. Mine is beautiful. Worth every penny.
06-07-2012, 06:07 PM | #11 |
Since it is tilt, that's a horse of a different color, those are very plentiful and cheap.
Here's one at classicparts: http://www.classicparts.com/Transmis...oducts/312/1/0 Cheers, |
06-07-2012, 11:56 PM | #12 | |
VA72C10
06-08-2012, 12:27 AM | #13 |
I will take your org for $22 please sir.
