Old 06-07-2012, 04:29 PM   #1
bigyellow
bigyellow's Avatar
cupholder idea!
so i've been tinkering with my old truck and think of stuff to do to it, and i had an idea while cleaning my dodge out for a road trip. i noticed in the back seat under the center console of the front seat was a cupholder that slides out into the back seat.
heres my idea, and somebody may have done it but why not take one and turn it around and mount it under out bench seat? that way it can slide back to look factory but still be functional?
Six in a row makes it go
bigyellow is offline   Reply With Quote
Old 06-07-2012, 10:13 PM   #2
Tinkermc
Re: cupholder idea!
if I'm not mistaken the 1 on my Dakota was plastic so mounting could be a small problem or maybe just remove entire thing as a unit
Tinkermc is offline   Reply With Quote
Old 06-07-2012, 10:45 PM   #3
bigyellow
bigyellow's Avatar
Re: cupholder idea!
thats what i'm saying. as far as i could tell from feeling under neath it, it's just two bolts holding it on. bolt that to the frame of ur seat and you'd be good.
Old 06-07-2012, 10:49 PM   #4
Str8-6-68
Str8-6-68's Avatar
Re: cupholder idea!
i like that idea i just might have to steal that idea from you when i get to the interior part of my build.
12ram3500 HS mm, FP 5" tbe, SB cai, 2.5" up, 35s on 20s. SOLD 02ram2500 twin turbo, built 47re, sticks & studs : SIKDZL -youtube.
68gmc1500 soon to be: shortbox, ppumped 24valve, s467.7, dap 300s, H2O/Air intecooled, meth controlled, 47re, 14bolt, 2wd.
Str8-6-68 is offline   Reply With Quote
Old 06-07-2012, 11:14 PM   #5
bigyellow
bigyellow's Avatar
Re: cupholder idea!
go for it, i put it out there for people to use. i'm going to try it too. i just need to go find a dodge in a junk yard that has one. i need a few other dodge interior pieces anyway
Old 06-08-2012, 08:42 AM   #6
koda360
koda360's Avatar
Re: cupholder idea!
I was thinking there was someone that sold these, only made of polished aluminum, or stainless. Not exactly what your referring to, but along the same lines....
1960 C-10
2000 Dakota R/T
1966 Fury I 2dr post
1984 Big Bronco
2002 Durango SLT (Bride's Ride)
koda360 is offline   Reply With Quote
Old 06-08-2012, 08:59 AM   #7
koda360
koda360's Avatar
Re: cupholder idea!
Something like this?
http://www.thehotrodgirl.com/bicupho.html
I've seen these made by several people, and several different prices. This is just the first one I came across. I know $80 is a lot to swallow for such a simple idea, but it would make a nice finishing touch. I'm just not a big fan of plastic parts in a metal truck..... but that's only my 3 cents!
1960 C-10
2000 Dakota R/T
1984 Big Bronco
Old 06-08-2012, 09:35 AM   #8
tomis blair
tomis blair's Avatar
Re: cupholder idea!
Do what i did and cleanned up an old wheel center cap, painted it and skrewed it down to the floor right in front of the seat. Works like a charm and i already had the center cap.
tomis blair is offline   Reply With Quote
Old 06-08-2012, 10:22 AM   #9
bigyellow
bigyellow's Avatar
Re: cupholder idea!
i just think it'd look nice and it'd be mostly hidden. it's black and not a shiny plastic. it'd blend in really well with a black bench, especially if you had a high hump
Old 06-08-2012, 10:32 AM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: cupholder idea!
There were aftermarket cup holders that would slide into the location of the stock ashtray in these trucks. But no body makes them anymore. They were pretty slick, cuz you would put the front cover from the ashtray on it and you wouldn't know a cupholder was in there.
If anyone knows if they are still available... that would be dope.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-08-2012, 10:33 AM   #11
MrSchaeferPants
MrSchaeferPants's Avatar
Re: cupholder idea!
I've been thinking of a cup holder for a while, think the best solution for me would be to modify the top of my buddy bucket console. There was a thread about a Toyota cup holder that fit into the ash tray I guess with some modification. Dunno about a bench.
68 GMC C2500 - 305 V6 - 4spd
MrSchaeferPants is offline   Reply With Quote
Old 06-08-2012, 10:40 AM   #12
Str8-6-68
Str8-6-68's Avatar
Re: cupholder idea!
GASoline71 That would be super slick, ive only seen the do it yourself thread on this. it would be nice to buy a replacement since i have an empty hole where the ash tray once was. hopefully there is still a direct cup holder replacement for the ash tray.
Old 06-08-2012, 11:15 AM   #13
dmw319
Re: cupholder idea!
id love to see some pictures! if you end up throwing something together be sure to post them up! i was thinking about this same thing the other day but havent thought of a good idea yet
dmw319 is offline   Reply With Quote
Old 06-08-2012, 11:40 AM   #14
Mufrat62
Re: cupholder idea!
I may be mistaken but wasn't there a 2 cupholders unit that fit in the ashtray hole in one of the latest LMC catalogues ?? I will have a look. It wouldn't be hidden at all however and it appearred that you lost the use of the ashtray because the cupholder fit right in there like the ashtray does.
Mufrat62 is offline   Reply With Quote
Old 06-08-2012, 04:39 PM   #15
MrSchaeferPants
Re: cupholder idea!
Just pulling random webpages. Not doing any research.
http://www.brotherstrucks.com/prodin...number=ATC6772
http://www.sporttruck.com/techarticl...ion/index.html
Like the tech article one. Now I didn't look to see if brothers still made that kit, but that type of cup holder is very common, factory in many newer cars. Sure you could aquire one and adapt to fit.
Old 06-08-2012, 10:53 PM   #16
Hubscrub
Cruzin
Hubscrub's Avatar
Re: cupholder idea!
i have built one that slides into the ash tray hole i have some old pics of it currently working on some better ones cleaner cut etc.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 06-08-2012, 11:09 PM   #17
bigyellow
bigyellow's Avatar
Re: cupholder idea!
i know those are functional but i don't they're particularly attractive, imo at least
Old 06-08-2012, 11:45 PM   #18
Hubscrub
Cruzin
Hubscrub's Avatar
Re: cupholder idea!
Originally Posted by MJs69CST View Post
Hubscrub---that looks real nice! While I haven't started thinking about a cupholder yet, I have to have something when my truck is done. Anyways, like what you have done.
thanks, it will work fine for me don't need it slide it out replace ash tray
Proverbs 3:5,6
