wheels revisited
I'm sure its been gone over before but I'd like to know if 67-70 Chevy/ GMC 6 LUG steel wheels with 3 Lumps on the hub cap circle,fit a 63 C10 w/ disc brake conversion?
Posted via Mobile Device |
![]() Join Date: Oct 2009
Re: wheels revisited
Although I'm not 100%, I'm pretty confident in saying that all "3 nub" wheels are drum compatible only.
![]() Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
Thanks for the reply. I was thinking the same thing but not being sure,I'll ask everytime.
![]() Join Date: Jun 2012
Would a stock 71 and up steel rim work with disc brakes then? I have a 69 that I just converted to disc brakes in the front. I really want to keep the stock looking wheels on it. will spacing the front wheels out help at all?
Find some from a 71+ 4x4 those should work
70 SWB STEPSIDE 70 BLAZER 09 challenger |
So, you're wanting to stick with stock steelies for hubcaps? If so, just walk through a junkyard and look for trucks with wheels that have 4 nubs. There are a lot of them out there, so it should be pretty easy to find a set.
wheels 71 and up r designed to clear disc brakes
