Old 06-07-2012, 11:14 PM   #1
sierra4x4
sierra4x4's Avatar
I can't believe it
I was just at the local garbage dump and found what looks like a 56 GMC or so 4x4. It is hard to tell because it is upside down and crumpled. Looks like its about a 3 ton. It looks like it has the original chevy v8 because their are no side motor mounts. Just the front ones beside the timing cover. I think its a 4 speed maybe 5 and still has the transfer case in it. I can't believe someone would send it to the dump. Looks like some company did a clean up because their are a couple of old 4x4 snow plows from the 50's as well as an old Dodge Power Wagon.
sierra4x4 is offline   Reply With Quote
Old 06-07-2012, 11:24 PM   #2
Trekster
Trekster's Avatar
Re: I can't believe it
That's too bad. Can you snag some parts off of it or does the dump frown on that?
Trekster is offline   Reply With Quote
Old 06-08-2012, 12:19 AM   #3
sierra4x4
sierra4x4's Avatar
I can take anything I want. Nobody there take or leave anything you want at this place. I'm going to grab the T-case and linkage for sure.
Old 06-08-2012, 12:32 AM   #4
meter swinger
meter swinger's Avatar
If its NAPCO stuff grab it. Can be worth some $$$.
Unbelievable what some people wont give a second thought to trashing.
meter swinger is offline   Reply With Quote
Old 06-08-2012, 12:43 AM   #5
OrrieG
OrrieG's Avatar
Get the front axle, should have NAPCO cast into the axle tube. That and the drivelines, transfer case and frame attachment, shift linkage are the parts you need. I think the rear axles had lift blocks. fender trim were part of the package too, but a lot of guys did not use them. v8 motor mounts are reproduced so not a big deal. GMC grille and parking light lenses are not reproduced either, lenses are very valuable.
OrrieG is offline   Reply With Quote
Old 06-08-2012, 08:13 AM   #6
B_Hix
B_Hix's Avatar
wow..sad end for a truck, but maybe you'll score some good parts
B_Hix is offline   Reply With Quote
Old 06-08-2012, 09:47 AM   #7
mr48chev
mr48chev's Avatar
Down here the scrappers would have snagged all of that stuff an cut it up and hauled it off.
Old 06-08-2012, 10:23 AM   #8
G&R's57GMC
G&R's57GMC's Avatar
Like they say 'One man's junk is another man's treasure'
G&R's57GMC is offline   Reply With Quote
