Old 06-08-2012, 10:20 AM   #1
BLUE SQUARE
BLUE SQUARE's Avatar
Anybody tow with a 5/7 drop on a Square? (Pictures).
Anybody have experience towing anything with a 5/7 drop or pictures? Please share your setup and pictures if you have them. Thanks, guys. BLUE SQUARE
BLUE SQUARE is offline   Reply With Quote
Old 06-08-2012, 02:48 PM   #2
king-918
king-918's Avatar
Re: Anybody tow with a 5/7 drop on a Square? (Pictures).
Curious about this too because I want 22 on mine and dropped
king-918 is offline   Reply With Quote
Old 06-09-2012, 12:31 AM   #3
Low Elco
PM Jonboy.
Low Elco is offline   Reply With Quote
Old 06-10-2012, 02:24 AM   #4
badfarmtruck
little over 5/7
badfarmtruck is offline   Reply With Quote
Old 06-10-2012, 09:56 AM   #5
walka
How much of a notch do you have?
walka is offline   Reply With Quote
Old 06-10-2012, 10:52 AM   #6
BLUE SQUARE
Awesome badfarmtruck. Thanks for the picture - It's good to see that you can still tow with that kind of drop. Although I'm willing to sacrifice all functionality to get my truck closer to the ground, I'm glad I can still use it to haul things if needed. What kind of setup do you have? Just a Flip and Shackles, or did you add helper bags?
Thanks- BLUE SQUARE
Old 06-10-2012, 02:23 PM   #7
SCOTI
SCOTI's Avatar
Flip kit, shackles, & HD c-sections (the type that wrap around the top/bottom plus the side of the frame rail) along w/an AOL set-up & towing isn't an issue.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-10-2012, 08:06 PM   #8
badfarmtruck
no notch on my truck. once i section my crossmember i am going to make a small step notch in the rear. right now it spindle/springs and flip kit/shackles. want it to bethat low but also ride nice
Old 06-10-2012, 10:40 PM   #9
SCOTI
SCOTI's Avatar
Even w/o a load in the back of my old 74, the >7" rear drop puts the axle tube very close to the frame rail. Mine had about 1" gap w/the flip kit (HD 8-leaf spring pack) & Bell Tech shackles.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-10-2012, 11:30 PM   #10
BLUE SQUARE
Great feedback SCOTI. Thanks- that gives me a pretty good idea of what I have to do. I will probably go 6 or 7 inches in the rear with a notch. Thanks, man.
Old 06-11-2012, 02:14 AM   #11
Square_78
Square_78's Avatar
Mine was about the same after the flip kit. About an inch of clearance. I have air shocks in the back right now, but i will eventually end up doing a c-notch so I can drive with the truck level all the time and not worry about the axle hitting the frame.
Square_78 is offline   Reply With Quote
Old 06-12-2012, 01:11 AM   #12
BLUE SQUARE
I plan on doing all the work once while I have the bed off. I will be ordering a western chassis flip and notch. Also, I will change the diff gear oil and power wash and clean everything really well - then I will apply a coat of eastwood. I will provide pics when I get to that point. I have more time than money, so I'm just doing my homework. Thanks again, guys!
