Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 06-08-2012, 10:27 AM   #1
Melnickta
What tools do I need to buy?
What tools are needed for simple maintenance and upkeep (nothing too fancy, such as big bodywork or removing an engine)? I’m fairly young, not terribly mechanical and have never had a project like this before. My everyday driver is a Mercedes ML 320 that I don’t dare touch for fear that, if I screw something up, it’s $2K to fix.
I have a small set of socket wrenches, and a set of regular wrenches. That’s about it.
What else do I need?
Melnickta is offline   Reply With Quote
Old 06-08-2012, 06:21 PM   #2
JointTech
JointTech's Avatar
Re: What tools do I need to buy?
plyers, 3/8 standard socket set. deep sockets. extenders. sparkplug socket. vice grips, channel locks. assorted screwdrivers. electrical tape, duct tape. some kind of light. i prefer the led ones that have a few plugs in the handle so it can be used as a drop cord and they dont break the bulb every time you drop it. breaker bar for your socket set.
with that you can pretty much fix anything minor. (and should probably be carried at all times in an old truck.)
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 06-08-2012, 08:50 PM   #3
RanchFlyer
You mentioned a socket set and some wrenches. I hope they are of suitable quality. Cheap tools only make more work for you. As far as things you don't have that you will wish you had.
Hammer
Pry Bar 24"-36"
4-way lug wrench.
Floor Jack and stands
3/8" extensions 3", 6", 12"
3/8" impact wobble joint
On sockets I use my 3/8" drive,deep,6 point. For 85% of the work on my 72.
RanchFlyer is offline   Reply With Quote
Old 06-09-2012, 12:52 AM   #4
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Something to stand on, rags and safety glasses.
And a camera.
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 06-09-2012, 11:33 AM   #5
Marv D
Registered Truck Offender
Marv D's Avatar
Originally Posted by RanchFlyer View Post
................Floor Jack and stands
Gotta ditto that one. Cheap jackstands are a disaster waiting to happen. Invest in jackstands like your life depended on it.
ones on the left are rated at 15,000 pounds each,, will hold a 3000 pound car 28" off the ground SOLIDLY and STABILY
Stupid over kill?? maybe,, but I was pinned under a car that fell off a jack once,,, it won't happen again.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 06-17-2012, 09:41 PM   #6
suspect
suspect's Avatar
anytime when you first buy another vehicle, the first thing you should buy is a repair manual; chilton, haynes, etc.
you can get most of your tools from harbor freight, steves wholesale, other discount tool places. you can get about 70% of the tools you need at these places for less than half the cost, but you will need to use good judgement on some choices. and you will get burned on a few, but that's how your going to gain judgement. (like don't buy cast pry bars)
Daniel
68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594
Romans 10:13 Everyone who calls on the name of the Lord will be saved.
suspect is offline   Reply With Quote
Old 06-17-2012, 09:54 PM   #7
71swb4x4
71swb4x4's Avatar
A lot of these tools you will have for the rest of your life, so put a little time and effort when looking for the pricier ones.
Someone on here once recommended high quality ratchets, and medium quality sockets. I think that is a good recomendation.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
