06-08-2012, 01:17 PM | #1 |
Rear bag question?
I have a c-notch with 5 inch coils and and 2 inch blocks on back now. If I replace coils with airbag kit in place of coils will it allow me to get rear lower or be the same height. Trying to keep the back out more still has some rake to it. Thx
Posted via Mobile Device |
06-08-2012, 02:55 PM | #2 |
Re: Rear bag question?
Sorry tryin to bring back down a little more. Didn't proof read.
06-10-2012, 03:15 PM | #3 | |
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390 |
06-10-2012, 03:16 PM | #4 |
what drop do you have in front
06-11-2012, 08:45 PM | #5 | |
06-11-2012, 10:39 PM | #6 |
Say you go with a Slam Specialties air bag. That air bag will collapse down to just under 3", which should sit your truck down pretty low when aired out. You can measure how high your coil is now with the weight of truck on it, then the difference to 3" is how much lower it will sit aired out.
Hope this info helps. Travis Posted via Mobile Device |
06-11-2012, 11:59 PM | #7 |
I will say lower since you can air it out and it will drop lower then the spring. Ride will probably be better too.
The rear is easy to do..
My build thread: 1966 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=486223 1965 GMC fleet http://67-72chevytrucks.com/vboard/s...d.php?t=651726 |
06-12-2012, 05:37 PM | #8 |
thx guys for info.
06-12-2012, 05:46 PM | #9 |
Who Me?
The bags should let you bottom out in the notch.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
