Old 06-08-2012, 03:40 PM   #1
B_derK20
Raw fuel smell with slider open
Hi all. My '83 K20 makes me sick every time I drive it with the rear slider opened. I looked at the sending units on both tanks and there are 3 lines for each one. The large ones go to the tank selector valves I'm guessing and Im not sure what the other ones are for. The 3rd line on each sending unit has 4 inches of hose with what looks like an axle vent stuck into it. I'm guessing that's where the raw fuel smell comes from. My question is is this how GM built it? The truck was built in Canada and I can't see where it ever had one of those charcoal canisters by the radiator. Would putting one of those in and running the vent lines from each tank to it fix my problem? It's hot here and I really need that window open since I don't have ac.
Thanks!
B_derK20 is offline   Reply With Quote
Old 06-08-2012, 04:57 PM   #2
bigwheel15
bigwheel15's Avatar
Re: Raw fuel smell with slider open
Where does your exhaust exit?
bigwheel15 is offline   Reply With Quote
Old 06-08-2012, 06:54 PM   #3
tucsonjwt
You guessed right. in 1983 3/4 ton pickups were considered "heavy duty" trucks and were not required to have a evaporative emissions canister. So, you have a short length of hose with a one way valve stuck in the end for venting purposes (yes, it is exactly the same as the rear axle vent - you can still buy them from Classic Parts.)
I bought 25' of fuel line and ran the line from the sending units to the rear bumper of my truck (terminating above the spare tire) and put new vent plugs in the end. This moves the gas smell from the cab area to the back of the truck. In the 100+ degree desert heat it really reeks of gas odor back there but it is better than odor in the cab.
See in the pic very far back inside the rear bumper for two light grey dots which are the differential vent caps used in the modification (I have dual tanks.)
tucsonjwt is offline   Reply With Quote
Old 06-08-2012, 08:32 PM   #4
hatzie
Moderator
hatzie's Avatar
I've run em into steel lines brazed through the bottom of the air cleaner. Gets rid of the smell.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
