Old 05-15-2003, 10:17 AM   #1
Razorback_Fan
Razorback_Fan's Avatar
What would cause this?
Ok I know that a hundred things could cause this but all info appreciated. Turn signals and brake lights do not work. As soon as you step on the brakes the fuse blows this also happens as soon as you use the turn signal. Any ideas? I got a feeling the signal switch is causing the turn signal problem but curious on what would cause both fuses to blow.
84 C-10
Want a free xbox 360 elite go here to see how http://geocities.com/razorbackfan90/
Razorback_Fan is offline   Reply With Quote
Old 05-15-2003, 10:54 AM   #2
bpmcgee
bpmcgee's Avatar
Okay, the stupid answer to your question:
There's too much current going through the fuse, and that causes it to blow.
I know, I know, not very helpful. But, if you think about it, maybe it leads somewhere.
Something is wrong which causes an over-current problem only when you use the switch. Is there current flowing through it when the switch is off, which causes it to go over when you use them? Or is there a short someplace which causes too much current to flow only when the switch is used?
Could the turn signal switch be bad? Both the brakes and the turn signals are wired up into it for the hazard light function.
Sorry, that's all I can think of,
Brian
bpmcgee is offline   Reply With Quote
Old 05-15-2003, 11:33 AM   #3
solidaxel
solidaxel's Avatar
Look for a SHORT to ground, or a pinched wire, follow the wire loom from the firewall to the rear and try and isolate it from the front or the rear lights. Keep looking you will find it !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-15-2003, 06:16 PM   #4
TROYLV
short
you are on the right track solid axle. the wire to the brake light runs from the turn signal fuse thru the brake switch to the the turnsignal switch in the column. then down the column to the bulkhead connection out to the wires back to the rear brake/turn lights. also goes to the front ones, but your brake light switch will not cause them to light up. designed that way in the turn switch. sooooo if it does it with the brake applied and or the turn switch then it is in the rear part of the wiring. could be anywhere from the turnswitch, down the column to the rear wires. again solid axle is correct, a bad ground will cause high resistance which causes high current. so check the grounds also.
troy wilson
TROYLV is offline   Reply With Quote
Old 05-15-2003, 07:12 PM   #5
TIMSPEED
TIMSPEED's Avatar
Razorback,
Trust me, there's a SHORT! I COULD NOT figure out why my B/U Lap fuse kept blowing, which in turn would cause my blinkers not to work. So, I remembered that I *SORTA* burned my wires when I cut off my bumpstops...so, I ran a few new wires, and good as new!
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 05-16-2003, 09:59 AM   #6
Razorback_Fan
How can I check the switch to see if it is bad? I had a mechanic adjust the switch because I could not dim my headlights after that is when the problem started.
84 C-10
Old 05-16-2003, 11:28 PM   #7
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Use a test light and put the clip at a 12v source. Probe all of the brake light wires at the dash. The wire that makes the test light come on is the one being grounded. Most tailights ground at the rear of the truck therefore you should only have a few wires that get 12v of power. I would suspect the wire that is for the brake light only. You said the lights work fine until you hit the pedal so its not the running light wire. Try to turn the signal on only and eliminate each wire one by one. Find the one thats grounded out and trace it down and repair as needed. Start in the rear and look for bare wiring. Good Luck
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 05-16-2003, 11:33 PM   #8
wHATANERD
wHATANERD's Avatar
Trailer Harness
Is your truck wired for a trailer Harness, I've seen some bazzar wiring behind the lisence plate, and if tape has came off it could easily cause a short
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 05-16-2003, 11:44 PM   #9
Bobs76
Bobs76's Avatar
Trust me it is the turn signal switch. They do go bad, My dad has a 72 that did that, I heard from a mechanic that that is what it does and sure enough that fixed the problem.
If it aint got t*ts or wheels I am not interested!!!!!!
Bobs76 is offline   Reply With Quote
Old 05-16-2003, 11:47 PM   #10
phantom dually
In this case unplug the harness then probe the wires at the harness plug. Check for a ground.
