Old 06-09-2012, 08:05 AM   #1
Weasel Diesel
Shop accident yields massive idea
Ok Guys, this is so simple, I feel SO stupid for not thinking of it sooner. As alot of readers know, I just got done replacing rocker panels & cab corners on my ride. Have been contemplating getting protection coating to spray inside them to avoid rust, however, most of them you have to order and are a tad expensive (i.e. Waxoyl or Eastwood anti rust ) 15.00 a can and have to buy a 50.00 gun & conical wand kit. I was in the shop and to make a long story short a can of DuPont Teflon Multi-Use lubricant got punctured. It srayed a thick coating of teflon all over. Before I could wipe it up it dried ( and I mean quickly ) and left a solid coating of teflon on my toolbox. While I was fussing & cussing, I made the joke " Wish I could get this type of stuff to put on the inside my Rockers, They'd never rust ". DOH..... Idiot,... I took another can, cut the red aerosol nozzle applicator straw in half, ran washer tubing between the 2 pieces, then on the end straw, melted the tip shut, took a hot needle and poked 4 holes arount the sides of the end to make a home made conical spray nozzle. Fed it up into the rocker and cut loose. PERFECT !! I have a well Teflon coated rocker inside. The product is so thin it flows into every crack & crevase. It totally dried quickly. It does just like the label says "Sets up dry". I wanted dry, cause oily stuff collects dirt and stuff. It is really stuck to it good and isn't coming off. The teflon is rated at -30F to 300F, so I dont have to worry here in Va about temp effecting it. 5.00 a can at Lowe's. I was so happy with the rocker result, I did the inside of my doors too !!
Weasel Diesel is offline   Reply With Quote
Old 06-09-2012, 09:02 AM   #2
74 shortbed 406
Re: Shop accident yields massive idea
That might not be a bad idea.
1978 GMC K25
2002 Dodge Dakota R/T rc swb
In need of some more goodies.
74 shortbed 406 is offline   Reply With Quote
Old 06-09-2012, 09:41 AM   #3
68Timber
I know the pieces fit
68Timber's Avatar
Cool. I was afraid somone lost a digit.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 06-09-2012, 11:46 AM   #4
Weasel Diesel
Haha... no, not today... I will say this, when that can punctured, I jumped like a cat crappin razor blades !!! Scared the crap out me.
Nothing that was within 10 feet of that can will rust anytime soon either!!! Including Me. By the way Head & Shoulders don't phase Teflon in yer hair.
Old 06-09-2012, 11:39 PM   #5
rs72z
rs72z's Avatar
I hope you have painted already, paint won't stick either.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 06-10-2012, 12:38 AM   #6
INSIDIOUS '86
INSIDIOUS '86's Avatar
So what about spray superglue will that stick to the teflon?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 06-10-2012, 12:47 AM   #7
DesertCat
DesertCat's Avatar
That's exactly what I was thinking. Your painter will hate you...
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 06-10-2012, 07:56 AM   #8
Weasel Diesel
I had painted the backside of the rocker before I installed it. Then the only part I teflon'd was the inside of the rocker, Nothing on outside where finish paint will be was touched. Doors were painted on inside ( like where regulator & stuff goes) before I did door insides. OMG, can you imagine how peeved a painter would be, Holy cow... hahahaha!
Old 06-11-2012, 12:03 PM   #9
rocking chevy
rocking chevy's Avatar
sounds like a good idea, thanks for sharing, I might do this to my pickup.
rocking chevy is offline   Reply With Quote
