how much play should i expect in a tilt?
Just installed a tilt column in my truck and was surprised at how nuch play there is in the tilt mechanism. I went through and checked all three bearing before installing they were fine and got repacked with grease. What did i miss?
Posted via Mobile Device |
Re: how much play should i expect in a tilt?
Are you talking about movement in the steering wheel area, or the knuckle for the tilt shaft....
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
I guess the knuckle. If i grab the steering wheel i can move it up and side to side a bit. It is pivoting about the tilt axis.
TILT COLUMN GURU
![]() Join Date: Dec 2006
Sounds like the housing bolts are loose.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
