Old 06-09-2012, 05:59 PM   #1
Pont406
Old fuel smell?
I'm redoing a fuel system on 69 c10. I welded 2 -8 fittings to a tank and ready to reinstall. Gas tank keeps on omitting nasty gas smell, kinda similar to an old paint smell. I ran plenty of water through it. Tank is clean inside. Should I boil it out or just run it as is?
Pont406 is offline   Reply With Quote
Old 06-09-2012, 06:01 PM   #2
doubleb's69
doubleb's69's Avatar
Re: Old fuel smell?
If it were mine I would make sure there isn't any rust in it and if not I would bolt it in and go. As long as its clean it shouldn't make a differance. It has just had gas in it for many years and its hard to remove that smell.
Bud
doubleb's69 is offline   Reply With Quote
Old 06-09-2012, 06:11 PM   #3
michael bustamante
michael bustamante's Avatar
Re: Old fuel smell?
you might as well get some muratic acid at home depot and use a 1 to 3 mixture (water) to swish around in the tank for a bit. its out anyways and itll eliminate any worry about old smelly gas and old varnish
1967custom
michael bustamante is offline   Reply With Quote
Old 06-09-2012, 09:36 PM   #4
hayhauler71
hayhauler71's Avatar
Re: Old fuel smell?
Dump 1 quart of acetone in the tank and slosh it around it will remove the water that is left over and the smell will be gone
Fuzzy
hayhauler71 is offline   Reply With Quote
