rusty 66
sway bar ?
Hi I just pick up a used sway bar for the pick-a-part it 1 1/4 and my 66 chevy truck never had one and I bought new energy suspension polyurethane bushing and wanted to know if I need the little bracket that site on the frame to mount it to the frame rails or can I just mount it the the frams I have 3 inch drop coil in the front and I cut a 1/2 round off the get it a little lower
1947 chevy fleetmaster http://www.cbforum.net/forum/ 1966 chevy c10 long bed http://67-72chevytrucks.com/vboard/s...d.php?t=439219 1970 chevy impala custom http://www.layitlow.com/forums/index...pic=349867&hl= |
Re: sway bar ?
I think you should use classic parts sway bar bracket for lowered trucks.
I have never seen the sway bar bolted directly to the frame http://www.classicparts.com/1963-87-...info/74-806-3/
'66 chevy lwb c10 '65 chevy lwb c20 |
Re: sway bar ?
Hey Juan!
Depending on what your truck has you may or may not need the mounting brackets , The reason I had to use them was because the powersteering conversion on my truck made the powersteering box hang too low and was in the way....but if you have stock steering or maybe a better powersteering bracket then the one I have you might be able to mount it right to the frame rails... heres a swaybar write up "txfirefighter" did on mounting your swaybar and also a updated section i added showing my power steering problem, and a number of places I found that sell the brackets....and also a picture with it mounted right to the frame that alot of guys do.. best bet would be to just bolt it up to the a-arms and see if youll need the mounting brackets or not! http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 Last edited by losthope; 06-10-2012 at 12:42 AM. |
