Old 06-10-2012, 03:36 PM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
WTB OEM floor pan screws to plug bench seat holes for bucket cab
Looking for the screws GM used on bucket cab trucks to plug the floor pan holes for bench set tracks. See the blue arrows on the attached pic borrowed from member Classic Bowties.
Could also use a set of the under-floor pan bucket brackets....
Thanks.
Old 06-10-2012, 07:41 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: WTB OEM floor pan screws to plug bench seat holes for bucket cab
Bump....
Old 06-10-2012, 09:05 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
ttt for you.....seems there'd be a market for these if someone can find something that looks the same and works....
i'm working on the under cab braces but can't find a good local fabricator....yet
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-10-2012, 10:38 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Would be nice. I'm told GM also used hex head screws in addition to the phillips head type. If you get some braces fabbed up let me know. I've got my K20 in the shop - with your old NOS door mocked up: http://67-72chevytrucks.com/vboard/s...d.php?t=528308
Old 06-20-2012, 01:28 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
FYI - Classic Parts of America and probably some board venders sell stainless panhead screws for the rear fenders that are a close approximation. These are slightly shorter than I imagine the real ones are.
Part # is: 37-978S (1941-87) Rear Fender Bolts-Phillips
Old 06-20-2012, 01:56 PM   #6
ls1nova71
ls1nova71's Avatar
I'm pretty sure these are the same screws they used in the top 2 holes in the bedside where it attaches to the front panel, and the screws used to hold the tailgate handle on and also the splash pans on a rear sport bumper. I just bought some from Jim Carter because they're also used to hold the rear fenders on stepsides. Hope this helps.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 09-22-2012, 11:03 AM   #7
budnikguy
budnikguy's Avatar
Just by the pic they look similar to the screws used to mount the BB heat shield to the cab floor..
budnikguy is offline   Reply With Quote
