WTB. Need a Auto trans drive shaft as core to cut Suburban
I need the front part of a suburban drive shaft. the Part that goes through the carrier bearing the smaller splines not the bigger which I have.
Its a little over 1" the bigger is not 1.5" but its bigger than the common bearing used by most Subs. I also need the yolk for the back after going through carrier bearing? |
| Bookmarks |
