Old 06-11-2012, 12:39 AM   #1
greasemonkey71
bbc swap
what would i need to do to swap a bbc with 400tb
into a 71 c10 2wd long
greasemonkey71 is offline   Reply With Quote
Old 08-11-2012, 04:31 AM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: bbc swap
Is it a sb or 6 cyl truck? Standard trans?
Either way, frame stands, motor mounts, larger radiator, matching shroud, pulley and brackets if not already equipped. Also IMO it's best to swap the engine harness if I was a 6 cyl.
If it was a 6 cyl truck you will also have to remove the engine mid mount by drilling or cutting the rivets. A sb is a little easier, just swap the stands.
If a manual trans you will need the auto cross member.
WIDESIDE72 is offline   Reply With Quote
