06-11-2012, 01:36 AM | #1 |
Front sheetmetal question
I'm ready to pull my engine & trans to get it ready for a dropmember. Thinking it would be easier to take the front end sheet metal off first. The hood is easy enough but cam someone tell me where the bolts are located to pull the nose off in one piece.
Thx in advance. Posted via Mobile Device |
06-11-2012, 09:26 AM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Front sheetmetal question
two or three bolts at the firewall, couple bolts under the cowl panel, one bolt inside fender well by exh manifold, one bolt lower rear fender. I think thats it.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-11-2012, 10:22 AM | #3 |
06-11-2012, 10:26 AM | #4 |
Also disconnect the wiring harness.
06-11-2012, 11:36 AM | #5 |
and the small sheet metal piece on the lower inner fender below the str column and the rad hoses
ron |
06-11-2012, 01:26 PM | #6 |
Thanks for the reply's. Is there a link for the location of the nuts & bolts?
[size=1d]Posted via Mobile Device[/size] Oh yeah the wiring harness? Does that just unplug from the firewall? |
06-11-2012, 02:08 PM | #7 |
you have to learn how to do some of these things for yourself. if you are going to continue to work on these things, that is how you learn . trying to figure things out for yourself. these vehicles are not complex
ron |
06-11-2012, 03:02 PM | #8 |
I have to agree with Padresag, however, be sure to bag and tag the bolts/nuts and small pieces so your project can go back together.
06-11-2012, 04:13 PM | #9 |
Thx for your tip
