Old 05-15-2003, 03:57 PM   #1
72gmcshorty
72gmcshorty's Avatar
Whats this wire for?
On my wiring harness, at the firewall junction, on the top row. One Red , one black, one black with white stripe. I know what the red and the black with white stripe are for but what about black? It's not in my wiring diagram. Its a 72 harness.
AND after doing the removal of external regulator, I should get a complete circuit from the tan wire in the harness to the white wire going to the alternator, correct? (when using a tester)
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 05-15-2003, 03:58 PM   #2
1969 GMC
1969 GMC's Avatar
isn't black usually ground?
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-15-2003, 05:24 PM   #3
72gmcshorty
In the wiring diagrams the ground wires for the headlight harness splice into a dark blue on one side and go straight to ground on the other side. This black wire begins right at the firewall connector and i have no idea what it connects to or where it goes.
1992 Gmc 2wd
Old 05-16-2003, 02:41 AM   #4
72gmcshorty
Anyone help? My manual doesn't show 72 wiring diagram.
1992 Gmc 2wd
Old 05-16-2003, 02:49 AM   #5
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Hey 72gmcshorty the black wire goes to the junction block on the pass side finder and connects with the pos side of the battery.
http://www.geocities.com/chevroletc1070/v8engcomp.html ...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 05-16-2003, 03:39 AM   #6
73stepside
73stepside's Avatar
black with whit stripe is for the ammeter guage it should have a fuse in it at the radiator support on either corner. that's how i chased it in the 70 chassis service manual
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 05-16-2003, 12:38 PM   #7
72gmcshorty
Thanks for the link. Any idea what size fuse is needed and what this wire is for?
1992 Gmc 2wd
Old 05-16-2003, 12:55 PM   #8
71Chev
71Chev's Avatar
4 amp
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 05-16-2003, 01:00 PM   #9
72gmcshorty
I mean the pure black wire. Not the one for the gauge
1992 Gmc 2wd
Old 05-16-2003, 01:13 PM   #10
71Chev
71Chev's Avatar
Both wires for the amp gauge take 4 amp fuses.
Old 05-16-2003, 01:20 PM   #11
72gmcshorty
There's 2 wires for the gauge? Now you have me confused. I know the black wire with white stripe has two inline fuses at 4 amps each. I'm sure this wire is for the gauge. I need to know about the solid black wire that is located right next to the black/white stripe wire on the firewall junction of the harness. In the diagram from the link above it shows the Black wire and the B/W wire as both having inline fuses. What size fuse is in the other wire? Look at the picture and you'll see what I mean.
1992 Gmc 2wd
Old 05-16-2003, 02:51 PM   #12
71Chev
71Chev's Avatar
The black wire that goes to the junction block takes a 4 amp.
the black w/ white stripe and the black going to the junction block are both for the amp gauge.
