Old 06-11-2012, 02:33 PM   #1
jrh55
Fuel sending unit
Hi all, any opinios on whether it is easier to drop a saddle tank or move the bed to get at the sending unit on my 75 C20??
jrh55 is offline   Reply With Quote
Old 06-11-2012, 03:36 PM   #2
MrMilks
MrMilks's Avatar
Re: Fuel sending unit
I have never removed the bed of mine, but dropping the tank isn't that hard. It can be heavy if it has fuel in it. I'm about to drop mine, I'm in the process of running mine dry so its easier to work with.
MrMilks is offline   Reply With Quote
Old 06-11-2012, 03:44 PM   #3
jrh55
Thanks, I'm just curious as to how to get the fuel lines off I can't really get a good purchase on them
Old 06-11-2012, 04:08 PM   #4
Laser145
I'm interested as well... since I'll be doing this soon.
1987 R10
1976 K10
Laser145 is offline   Reply With Quote
Old 06-11-2012, 04:14 PM   #5
Hevy
Hevy's Avatar
I'd drop the tank. Disconnect the lines after you lower it a few inches.
Hevy is offline   Reply With Quote
Old 06-11-2012, 04:21 PM   #6
jrh55
thanks heavy, doesn't look like there is enough hose for it but i'll give that a try
Old 06-11-2012, 04:30 PM   #7
Hevy
Hevy's Avatar
If you have help you can lift off the bed...
Old 06-11-2012, 05:04 PM   #8
tinydb84
tinydb84's Avatar
Its way easier to drop the tank. Put a jack and a couple jack stands under it and remove the bolts. You can disconnect the rubber lines from the hard lines under the bed. Just be sure to remove the little strap from the frame that holds the lines.
Old 06-11-2012, 08:47 PM   #9
hatzie
Moderator
hatzie's Avatar
Dropping the tank is a PITA. The sender hoses never cooperate with me. If I'm not replacing the tank I pull the bed. It's much quicker.
I've pulled a bed in 15 minutes or less with help for 2-3 minutes of it. 3-4 guys can move an unhooked long bed to sawhorses real quick. I've done a shorty with just two of us.
Unplug the taillights on the LH frame rail and the license lights at the center. Undo the filler neck and pull the rubber couplers. New bed bolts are cheap. If they don't move with a 3/8" ratchet I cut em off.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-11-2012, 09:14 PM   #10
orbot
orbot's Avatar
if yo have access to a motorcycle jack or tranny jack the job gets easier, if not well make sure the tank is empty, 4 bolts and 3 hoses and goes down, remember to disconect the ground wire.
orbot is offline   Reply With Quote
Old 06-11-2012, 11:37 PM   #11
lowesguy
lowesguy's Avatar
Only took me 30 min to drop mine,floor jack under it makes it easy! that was the passenger side ,had one on drivers side ,but removed it 8 years ago,ya know the exploding on impact thing!
lowesguy is offline   Reply With Quote
Old 06-12-2012, 01:56 AM   #12
bowtiemanchevyman
bowtiemanchevyman's Avatar
all you have to do is unhook the line as the switching thing and then just drop the tank. but be for you do plug the lines so nothing get in it. if its empty it takes like 10 15 min to do the job as long as the bolts comes out easy.
bowtiemanchevyman is offline   Reply With Quote
Old 06-12-2012, 02:46 AM   #13
jrh55
thanks all, my brother came over we did the bed thing wasn't bad
