Old 06-11-2012, 05:28 PM   #1
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
Talking Led Rear Light Question?
Upgrading my rear taillights to led. If i am just changing the rear tailights to led do i have to do anything with my flasher? (stock flasher or upgrade?)
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 06-11-2012, 06:03 PM   #2
Andy4639
Old member
Andy4639's Avatar
Cool Re: Led Rear Light Question?
I used the stock type for just the rear.
I just put front in and had to swap them to the LED with grounds to get them to work.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 06-11-2012, 07:22 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If you use LED's for turn signals, you MIGHT find that they blink fast. I just got an electronic flasher for mine and that was all I had to do on my '69.
On my '96, I had to wire a 6-ohm, 50-watt resistor in parallel with the filament. It makes them flash correctly, but when an incandescent bulb is used in place of the LED, the flasher works correctly and you won't know if the bulb is working or not...based on the way it flashes inside.
Member Nr. 2770
Old 06-11-2012, 07:27 PM   #4
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I have the LED's from LMC on the rear and stock flasher, works well.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
