Sound Deadening and New Upholstery!
Well i figured i should quiet the pickup down a bit and put some new skin on the seat and also door panels.
Upholstery was bought from www.ricksupholstery.com very easy to work with and fit everything to my needs and wants. Sound deadening was fatmat's Rattletrap 80mil. bought two 50ft^2 rolls and put two layers on floor and one layer on each door plus a layer behind the gas tank. used around 70 or so sq.ft. It is now MUCH MUCH quieter going down the road, i couldn't believe it at first. you can barely tell there is a motor in the thing. upholstery makes the ride much more comfortable and looks great. would recommend them to anyone.
1969 C-10 LWB 388 SBC Vortec Heads 10:1 Lunati 60103 cam Weiand intake Quadrajet Carb 12 Bolt 3:73 posi 700r4 Hedman Headers 1998 Dodge Ram 1500 Reg. Cab Long Box 4X4 5.9L 183k miles 1956 Ford F-100 Longbed with Original 272 and 3OTT 1995 C1500 ECSB 6.5 Diesel 4l80e (Camper puller) 1997 Dodge 3/4 ECLB V10 (MPG machine) ![]() |
Re: Sound Deadening and New Upholstery!
Looks great!Just put 2 layers of 50 mil fatmat in this weekend as well.Hoping for some help with heat also,getting ready for some Vintage Air.Do you notice less heat?Thanks.
Old member
Good looking job on the inner's! I want to do the sound deadner also at some point.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
dazed and confused
Looks great!
members met: redbaron69, billsbowtie,nc67 |
![]() Join Date: May 2012
looks good, i also need to do more sound deadening to ole dollar also, did some on the floor but need to do the doors and firewall ....it sure helps the heat to...
I haven't noticed any difference but i haven't driven it more than 20 miles at once since i put it back together. The noise for sure went down though!
