Old 06-11-2012, 07:09 PM   #1
Wildstreak
"something witty here"
Wildstreak's Avatar
bbc sm465 question
Im doin a bbc swap into a 68 4x4 I have a sm465 with a np205 from a small block I would like to use, do I need a new bellhouse or is the bellhouse the same for both?
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 06-11-2012, 09:01 PM   #2
rcbildr
rcbildr's Avatar
Re: bbc sm465 question
IIRC the bellhousing should be the same for both.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 06-12-2012, 12:57 AM   #3
snj8198
snj8198's Avatar
yep, bolt em up. your z-bar may be different. look into that perhaps. otherwise there is no issue.
have fun with the new big block!
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 06-12-2012, 08:33 AM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
Bell will work.
I have heard of problems with valve covers hitting the fire wall and the frame having to be notched for exhaust manifolds/headers. I've personally never did the swap so i have no 1st hand experience.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 06-12-2012, 09:48 AM   #5
snj8198
snj8198's Avatar
Originally Posted by OLDCHEV4X4 View Post
Bell will work.
oh ya, thanks for the reminder. Some have valve cover clearance issues and some do not. If you plan to run full roller rockers you'll need to use tall valve covers to clear them, this is where most people run into firewall clearance when converting to a big block. When i do it again i will move the motor to the forward set of mounting holes on the frame and extend the drive shaft. This will alleviate a lot of the clearance issues with both the covers as well as the tight fit for an HEI dizzy. -steve
Steve
