Old 05-15-2003, 05:24 PM   #1
dc oaks
Question frame cutting
what does everyone use to cut their frames with.
ride hard and never give up!!!!
dc oaks is offline   Reply With Quote
Old 05-15-2003, 06:46 PM   #2
TX_Mudder
I haven't done it, but I would probably use a 7" circular saw with a metal grinding blade. Would be the easiest way to make a nice cut.
-- Mike
TX_Mudder is offline   Reply With Quote
Old 05-22-2003, 01:40 AM   #3
MAC67
" SHOW ME"
MAC67's Avatar
i use the good ole hot wrench " CUTTING TORCH",, just remember if you are going to do some welding on it never weld verticle,, you will only end up creating a weak spot,,, always cut the frame at a about a 45 degree or more angle the weld that and plate it with 1.4 inch plating then you can be pretty safe feeling
MAC67 is offline   Reply With Quote
Old 05-27-2003, 03:33 AM   #4
gregbr
Senoir Member
gregbr's Avatar
First, I marked the area to be removed, 2 marks down the frame. Then I made a rough cut with the cutting torch and left the frame an inch longer than needed. Then I made the final cut with a porta-band saw. I then cut on the frame on the other end of the part to be removed, then pulled it together and welded it. I then took the piece removed from each side, cut it longways and removed about 1/2" then welded this piece inside the frame for extra support. Remember, the worst thing you can do is to get in a hurry. Do it right the first time.
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 05-28-2003, 05:48 AM   #5
ZOOMY
frame
The best frame splice I have even seen on these trucks was done by EFABMAN. Do a search & you might find it.
ZOOMY is offline   Reply With Quote
Old 05-28-2003, 10:54 AM   #6
Mudder
Mudder's Avatar
agreed with Zoomy. I kept those pics just for me.
Old 05-30-2003, 08:23 AM   #7
dc oaks
thanks guys going to do the search now.
Old 05-30-2003, 11:56 AM   #8
ljbear
ljbear's Avatar
Earl has a series of pictures on his web site that show pretty clearly the steps. Go here:
http://ebfabman.com
drop down and find the pictures. The frame cutting start from pic #14 on.
Larry
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
Old 06-20-2003, 11:08 PM   #9
stlaser
Fabricator
If you cut it at a 30 degree angle instead of a forty five it will be considerably stronger. Just a thought from a young punk fabricator/ wanna be engineer. If you don't believe me look at crane booms or steel over head fabricated beams. All have 30 degree angles in them. Good luck
84 C30 Chassis 60 & 14, 454/400/NP205 Retroing 98 X-tended Cab
Built with the blood and sweat from the hands of a Chevy man.
stlaser is offline   Reply With Quote
Old 06-20-2003, 11:57 PM   #10
ozarkhippie
you can use a sawsall
Buy Sale or Trade
71 3/4 4x4
72 1/2 ton cheyenne 4x4
ozarkhippie is offline   Reply With Quote
Old 06-21-2003, 02:02 PM   #11
ljbear
ljbear's Avatar
Stronger Yet
I think the way Earl (efabman) does it beats them all. More surface area along the joint is the way to go.
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
Old 06-21-2003, 02:04 PM   #12
ljbear
ljbear's Avatar
Very Nice
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
Old 06-25-2003, 01:40 AM   #13
Richard
I have used a sawzall to cut frames with no problem. When I tore the frame in half on my 85 K10 the frame shop pulled the frame back together, welded the seam after ginding a V into the break and plated the inside and bottom of the frame. What he did that I noticed was a little different is that the plates he fabricated for the back and bottom rails had several 1/2" holes drilled in them and the holes were filled with a weld bonding the center section of the mending pieces to the rail as well as the edges.
Richard
Old 06-25-2003, 10:06 AM   #14
MAC67
" SHOW ME"
MAC67's Avatar
hi richard thats exactl;y how i fixed the frame on my 80 k 20 i tried to steer clear of the continuous straight line welds and i di the PLUG welds like was done to youres,, except i sued 3/4 inch holes,, i would have loved to been able to do eabmans way but those 73 and up frames have way to many whoops and dips,,lol
mac
