what is a good axle gear ratio
I have a 66 c10 with a 327 engine with a 3 speed. need to change the rear axle gears so i can keep up on the highway. I have 4:56 gears and run 60-65 max, any faster I will blow up the engine. What is a good all around gear ratio to run 70 comfortably but not totally lose my pull from starts?
![]() Join Date: May 2012
Re: what is a good axle gear ratio
i would say try a 308, i have a 276 in ole dollar and its a 292 six, with a granny 4 speed , went from 373 to 276 and i am at 2000 rpm at 67 mph. i was at 3000 rpm at 70 mph....and i did not like the rpm...or at 2000 rpm i was at 50 mph. did not like having to drive at 50 mph. i am getting over 18 mpg with this setup , just my 2 cents worth, hope this help you out a little.....
![]() Join Date: Oct 2010
I'm in the same situation just blew up an LT1 motor my dad put in an old 72 Pu, I couldn't hear the transmission winning. Mine 465. At least I want a 373 but a 342, 323 308, or 273 would be a dream
Chuck ![]() |
Is it an eaton rear end. If so I think the best you can do is a 410 unless you do an axle swap. I think an axle swap us cheaper anyhow
Chuck ![]() |
from my experience 3.08 is a little tall to expect a good pull from a dead stop out of. i would do atleast a 3.42
1967 c10 stepside 6.0L 4L80E ![]() |
The 3.42 is a real nice ratio as mentioned, good on highway and good around town too.
![]() Join Date: Oct 2009
66clow, the real question is whether or not you plan to retain the 3 speed. If so, then I agree with the 3.23 or 3.42 crowd. If there's a possibility of an overdrive trans in your future (say a T5 if you stay manual or 700R4 if you switch to an auto), then I'd consider a switch down to 3.42 or 3.73.
EDIT - btw, 3.08 and 3.73 is what was available from the factory in 66, so either will work, but you'll severely sacrifice low-end grunt for hi-speed cruising comfort with a 3.08. And that might be ok. All depends on your goal - and if it is truly highway driving and you are going to retain the 3 speed, then a 3.08 will work - BUT, since you have to change to get there, a 3.23 (or 3.42) might be more workable. |
![]() Join Date: Aug 2010
I have heard that unless another ratio was specified, the 373 was assigned by default. A middle of the road ratio to suit the widest needs.
#9 | |
My 63 has the 3.08 and I still think it turns up pretty good going down the high way ,of course no body drives under 70 mph here in the motor city,so I guess it depends on if you are going to swap in an overdrive trans , or run a taller tire... My other truck , that was my DD when I lived in Maine had 3.73 and I never showed it any mercy 65 0r 70 mph was normal and I just let it sing...
Thanks for all the info. Think ill try the 3:42 for the all around. Here in Atlanta all the roads are 65-70.plan to keep the 3 speed for the coolness. No plans for drag racing so I can sacrifice some low end.
Posted via Mobile Device |
