Need help with 5/5 drop
Hello I did the 5/5 drop kit on my 79 silverado and would like to hear some feed back on anyone who as done this drop on the ride. I have the 3" spindle 2" spring on the front with stock rally wheels. The front wheels rub when I turn the wheel all the way. And the bottom bum stops have less then an inch of space. when I drive the tires rub the top of the inner fenders. Is this normal for this drop. I am ready to go back to stock.... Also the kit came with the shock but there is no travel in the shock. Can you guys give some advise on what way to go with this drop kit. I love the look of the drop but not like'n the ride. I did have to do a baby notch in the rear as well. Thanks guy Will post some pics soon
Re: Need help with 5/5 drop
It sounds to me you need to grind a little off the front edge of your lower control arms for the rims to clear lock to lock. Your front tires may be too big. Also you need to remove your front bumpstop mounts.
John 82 Chevy Silverado 350ci/TH350 ![]() |
J Knight nailed it..With the 3" spindle my weights rub on the lower control arm on a lock to lock turn. So I don't do them..lol. (also had to grind the caliper)
I'm running a 30x9.5 with plenty of room. |
I do try to avoid them lock to lock turns for that reason as well. I may have to grind some more off the a-arms and calipers. The front tires I am running right now are 255-60r15 on the stock rally wheels. What about the shock problem should there be more travel
Here is a pic of the shock mounted on the front end of the truck right now. Sorry not a clear pic but you can get an idea of what I mean
I have new stock shocks with no problems..(1.5" drop coils)
DON'T go back to stock. Once you finish grinding you will be real happy! |
Thanks Rich I really dont want to go back to stock but this has been a long battle for someone who really dont know much about the suspension part of the trucks.I posted a pic of the drop shocks mounted in the truck
It's the wrong shock almost looks like a rear shock send it back and get the right shocks.trim the lower control ARM for tire rub and remove the factory bumpstop factory tire size will not work with a 5" drop
Posted via Mobile Device |
I have been looking into the doetsch nitro slammers shocks for the front hoping that they will help with more travel and help with bottoming out on the inner fender walls. So what size tires should I run with this drop you think.
You don't need those hi dollar drop shocks on the front. Stocks are ok for a 2in spring drop.
backspace on the wheel is the issue.
I have used 2.5" and 3" drop spindles,... and if the wheel has a 4" backspace you will need to do some clearancing on the lower control arm around the ball joint area. My understanding is the 7" rallye will clear just fine It's not a big deal. If you don't mind doing a little extra work to make them clear, the 3" spindle is the way to go. It's much better to have spindle drop where you can rather than spring drop. The spindle will on effect the ride, whereas the shorter the spring the stiffer it becomes I've had good luck with Belltech and KYB shocks. I hear Bilstein's are top quality shocks also. I prefer the extenders because of the additional length of travel and the degree of operating angle they provide. relocating the brackets to gain as much travel as possible. The goal is to utilize the longest stroke for shock travel within the limits of the suspensions travel. There's more than 1 thread on cheap/free shock mod's you can do w/basic hand tools & such. Then if you still need to do drop shocks, get some that are specific to your application so you're getting the best performance out of them. |
#12 | |
Thanks I will look into that this all good info for me I really dont want to go back to stock hight. You mentioned shock extenders now you refering to the rear oe the front. I did notch the rear(baby notch) & put the extenders in the rear. But do they make some for the front as well I would love to have a stock sized shock in the front. Posted via Mobile Device |
#13 |
You can put stock size rear shocks on the front.
#14 |
I posted a pic of the drip shock the kit came with and the is no travel and thats a drop shock now if I run a stock shock wouldn't it be worse
#15 |
#16 |
Im running 255/60-15s on the front of mine with a already installed 3/1 drop which will change to at least a 5/4 but I also think a 255 seems pretty big for the front. I will go 235 or maybe 225 Im thinking. Also, dont they make front shock mount extensions for lowering? This would allow you to keep the shocks you have now. Or maybe new mounting studs relocated to allow the distance you need?
#17 |
I just finished a 5/5 drop on mine today and the stance is awsome. 32" tall tires will not work...LOL. My inner fender is sitting on the tire, so I am now looking into new tires for the front.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
#18 |
Well guy just finished some more grinding on the c.a. and calipers and that helped out a lot and now the only problem is trying to find a drop shock that is not compressed all the way when installed. Another question is what size tired should i be running on the front with the 5 inch drop I have 255-60r15 what size should i use so I do not hit the upper inner fender walls. Thanks again guy much help and good info.
#19 |
![]() Join Date: Mar 2012
255/60 is way to big for a 5" drop. You need a 235/60R15
Get stock size shocks for the front. Dont need "Drop shocks" for a 2" spring lowering. My front end is down 4.5" with springs and I am running stock size shocks in the front and they have lots of travel. |
#20 | |
Ok thanks I will look into getting some more new tires for the front then. Do you rub our hit the inner fenders with you drop. And my control arms Bottom is sitting ont he bump stop should they be removed as well ? |
#21 | ||
http://www.stylintrucks.com/parts/bu...0114_3322.aspx
#22 | |
#23 |
No you dont have to remove the inner fenders. It wont rub once you change your tires or when you remove the bumpstops.
#24 |
#25 |
Are you sure you ended up with a 2" drop spring??? kinda sounds way too low????
also don't pull the front bump stops, you can just jack up your truck, hang the front suspension so you have room to work, and take a sawzall to the rubber stops, cut the top half off, that way you have more travel, but also don't bottom steel on steel!!!! and you currently have the wrong shocks on the front of your truck, they are too long, Unless you have more then a 2" drop spring????? the spindles won't affect shock length 255 60 15 should fit |
