weights on front drum and hub question
i am going to get my original drums turned and was curious if i remove the hub from the drum will it set the weights off? one has a weight and one doesn't. Rod.
![]() Join Date: Oct 2011
Re: weights on front drum and hub question
The weight is there to balance the drum. It got balanced before it got put on the hub. Those drum's have got to be shot by now unless low mile's.
i just talked to 2 brake shops and said there are very turnable. not sure on the mileage but they still look fairly thick with next to no ridge. i hear the new ones aren't as good as the originals so i would rather use these. so i can remove them without a problem then. Thanks.
should these be left together? is there a reason gm did this? maby to make sure when you checked your front brakes you had to check your bearings at the same time. just for maintenance?
Have them resurfaced with the hubs attached they will be more true
Fuzzy |
#6 | |
~Rest In Peace~
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
Active Member
![]() Join Date: Jul 2007
Yeah don't remove them from the hub.. I just had mine surfaced last year and I was told to bring them in with the hub.
i think i will leave them together. thanks for the info
