Old 06-12-2012, 05:47 PM   #1
mac808
mac808's Avatar
Belltech Street Performance Shocks-'68 C10
Just wanted to post up a mini-review as promised to one of our vendors - The Suspension Source - who hooked me up with a set of Belltech Street Performance shocks for my '68. Awesome service and great prices. Highly recommended vendor for members looking for shocks and other suspension parts.
First off, I had no hesitation going with Belltech to replace my worn KYB GR2's since I've run them on all of my previous trucks - the most recent being a '08 GMC Sierra Crew cab lowered 4/6 and a '99 Chevy Silverado dropped 5/7 before that - and I've had nothing but great results. I've tried KYB, Edelbrock, DJM in the past and none felt as tight and compliant as the BT's. I've also used the Nitro Drop 2 shocks from BT as well but I found that the new Street Performance shocks are a notch above even those.
The shocks came with the proper dual eyelets for our application for both front and back. The BT shocks also comes with new nuts, washers and shock mount relocator pin. My truck already had the relocators so I didn't need to use them.
Installation is a simple swap for the front. I ran into a small problem on the rear with the pressed in lower eyelet on the BT shock being a hair too small for the relocator pin. A simple 5/8 drill to enlarge the eyelet hole allowed it to slip right on and bolt up right.
Once the truck was back on the ground, a quick test drive immediately showed improvement over the KYB GR2's. The ride is firm but smooth. No harshness or stiff jarring ride. Just a nice sporty, solid ride. It absorbed all of the low speed bumps and road surface textures nicely. I can't speak for its high speed feel and capabilities yet as I was only able to do a quick test drive around the neighborhood and haven't been able to take her out on the highway at higher speeds.
So far, though, there is definitely a much improved feel in low speed damping. I will report back once I'm able to get it up to speed and take a couple of off-ramps and hit higher speed bumps such as freeway joints etc.
Overall, I am very pleased with the BT shocks and their performance. Thanks again to The Suspension Source for the hook up on these.
mac808 is offline   Reply With Quote
Old 06-13-2012, 07:53 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Belltech Street Performance Shocks-'68 C10
Great news!
Would you mind posting the BellTech part numbers?
Also,... what drop does your '68 have?
Keith
Convert to disc brakes.
Old 06-17-2012, 09:36 PM   #3
kingsolver72
10/30/19
kingsolver72's Avatar
Not trying to be a wise guy but the picture of the boxes give the part #s.
kingsolver72 is offline   Reply With Quote
Old 06-18-2012, 10:57 AM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Pretty sure its an ECE 4/6
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-21-2012, 06:20 AM   #5
mac808
mac808's Avatar
Great news!
Posted up the pic of the boxes just for that reason lolife99. Great shocks so far. Very happy with them.
I am currently running the ECE 4/6 as mentioned above.
Old 05-04-2016, 02:29 AM   #6
xxblade31
xxblade31's Avatar
I know this is an old post. but I just bought a pair of these shocks from summit and the dust shields hit. Is there a different mounting area for the shock top that gives more clearance ? I see you mentioned relocation ?
xxblade31 is offline   Reply With Quote
Old 04-29-2017, 11:40 PM   #7
jessemthompson
I think this is going to be my next suspension purchase. The KYBs I have aren't bad, but they definitely aren't a performance shock. I'm hoping to see some decent improvement.
jessemthompson is offline   Reply With Quote
