Old 06-12-2012, 06:03 PM   #1
tomis blair
tomis blair's Avatar
Help with mysterious idle issue
So ever since i got my 69 running it has had a low (500)ish idle "no tach". I did a compression check yesterday just to make sure everything internal was ok, I started on the front cylinder on the passanger side head and and worked my way back. When i got to the third one back the plug wire broke and the little clip was still on the spark plug. So i went ahead and replaced all the plug wires with AC Delco wires and now my idle is higher (1000-1100)ish. Just going off of sound. Its high enough i can let the clutch go in 2nd like its the granny gear.
Has anyone else had this issue before?
Maybe i was running on less than 8 cylinders before and now all 8 are firing and the idle needs to be adjusted?
Any help will be much appreciated.
tomis blair is offline   Reply With Quote
Old 06-12-2012, 06:46 PM   #2
DesertCat
DesertCat's Avatar
Re: Help with mysterious idle issue
Yup
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 06-12-2012, 07:15 PM   #3
ole dollor
ole dollor's Avatar
might just reset the carb, check timing, and give it a once over, and reset the idle screw... good to here it was simple....
ole dollor is offline   Reply With Quote
