Old 06-12-2012, 09:42 PM   #1
jrh55
fuel tank switching solenoid
Hey all you way smarter mechanics than me, how do I test the solenoid on the frame rail for switching tanks?? Finally have both gauges working more or less correctly, the fuel gauge still bounces like crazy while driving but hey it's only for approximates anyway....
As always my many thanks to you all for all your help
John
jrh55 is offline   Reply With Quote
Old 06-12-2012, 11:03 PM   #2
hopelessredneck
hopelessredneck's Avatar
Re: fuel tank switching solenoid
the way my i did it was 1 empty tank 1 tank with gas with truck not running filck switch back and forth listen for sound from solenoid with running go from full tank to empy if truck started to die switch back then it should stay alive
1978 GMC C25 LWB
hopelessredneck is offline   Reply With Quote
Old 06-13-2012, 12:11 AM   #3
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Try putting power to the switch on the valve and double check your grounds on the sending unit wires:
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
