Old 06-12-2012, 10:03 PM   #1
Leadfoot Lambert
Leadfoot Lambert's Avatar
Who sells good rear cab supports?
My truck needs rear cab supports, I want the best fitting ones I can buy, who sells the good ones?
65 Chevy short fleet 350 5 speed, soon to be LSX powered
65 F100 short fleet
91 Heritage softail
94 Fatboy
11 Softail Deluxe [wife's bike]
13 Streetglide
http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz
Leadfoot Lambert is offline   Reply With Quote
Old 06-13-2012, 03:22 AM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Who sells good rear cab supports?
just realized you need the rust patch panel that is welded to the cab? that I do not know...
Old 06-13-2012, 08:37 AM   #3
awbrown
Being as i just installed 2 in mine , I can not recomend any of the ones I used .. one I cut in 2 and installed it in pcs. the other I got to go in in 1 pc. but did some creative reforming ,welding it just around the perimeter after hammering the edges so they contacted base metal...
awbrown is offline   Reply With Quote
Old 06-13-2012, 09:09 AM   #4
k1rodeoboater
Yeah mine fit like crap too. You would almost be better off making your own out of flat sheet to be honest
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
k1rodeoboater is offline   Reply With Quote
Old 06-13-2012, 10:50 AM   #5
vin63
It's Better With Nitro
vin63's Avatar
Just before I coated the bottom side of my cab, I ended up fabricating the rear braces from left over .032 sheet steel. I cut out the braces and used them as templates.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-13-2012, 06:48 PM   #6
Leadfoot Lambert
I ended up ordering a pair from top banana, at $10 each I figured what the hell, I'll post up my thoughts when they show up.
65 F100 short fleet
91 Heritage softail
94 Fatboy
13 Streetglide
