06-13-2012, 10:47 AM | #1 |
Outer roof skin removal??
Anyone know how to take the outer roof skin off of a 72 cab? How are the spot welds removed on the back seam? Would like to save the panel if I can as it has the clearance lights (fireman hats) and want to sell it. Any ideas? Thanks!
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
06-13-2012, 10:51 AM | #2 |
Re: Outer roof skin removal??
Interesting!
1968 Chevy C/10 LWB V8 1983 K5 Blazer 1989 C1500 Stepside Reg. Cab V8 |
06-13-2012, 11:01 AM | #3 |
Over on the AD truck side we depend on the assembly manuals to figure out where the spot welds are quite a bit and the manuals usually have the exact measurements you need when you are working on the body or chassis. Worth the 30 something bucks if you are going to do much panel removal/replacement.
This is just for example http://www.ebay.com/itm/1967-1972-CH...8e419c&vxp=mtr There are a lot of them for sale by different vendors on Ebay and they can be bought through Amazon. There it might make more sense now. Last edited by mr48chev; 06-13-2012 at 11:24 AM. |
06-13-2012, 01:32 PM | #4 | |
In other words, its a nightmare to remove it. |
06-13-2012, 04:47 PM | #5 |
If you want to sell the roof skin, I would recommend just cutting through the "A" and "B" pillars with a sawzall, and letting the buyer separate the parts to their liking. Honestly, it would be a lot easier to cut holes in a roof without lights, to add them, than it would be to replace the skin with another used skin.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
06-13-2012, 05:41 PM | #6 |
If it has the raised pads for the lights I can see wanting to save it. Are you trying to save the panel, or the cab to put a markerless roof on? Either way here are a couple of pictures to ponder.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
06-13-2012, 06:13 PM | #7 |
if you did not care about saving it I took one off in my project with an air hammer. Going to be hard to save unless its a cab you cutting apart and can cut pillars with it.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern" 1984 Silverado Red Baron-72 c10 Project |
06-13-2012, 07:11 PM | #8 |
I got a rust free cab that spent its entire life in Phoenix. Unfortunately for me it was a 1 ton cab and has the fireman hats. But it is original paint and 99.9 percent rust free so I would rather do the roof skin then rockers/cab corners/half the floor/cowl vent/drip rails/etc. If I HAVE to tear up the roof skin I will but since there is not an aftermarket roof skin with lights and since this one is immaculate I thought I would try to sell it. I am planning on buying a new aftermarket plain skin.
06-13-2012, 08:05 PM | #9 |
Roadtrip!
Not sure how much work is involved but they must have done it some back in the day. I have an NOS roof skin still in the package.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
06-13-2012, 08:18 PM | #10 |
I'm guessing that marker lights don't work for you. They were an option pretty much across the board. On the reskin, are you doing it or having someone else do it? This is not a good place to learn. Either way I'd seek out someone who has used the brand panel of choice and see if they did a complete replacement or just trim and lap before commiting. Depending on skills involved it might be a lot easier replacing the front third only. That will take a very close fit and good butt welding.
06-13-2012, 09:23 PM | #11 |
06-13-2012, 09:31 PM | #12 |
There's gonna be something sacrificed; either the skin or cab back panel-no question. I've done it to fix sunroof/cab lights, good luck drilling the egg shaped 1/4"spot welds at the rear seam!
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
06-14-2012, 06:32 AM | #13 |
Use a cut off wheel down the rear seam for removal, then the new owner can just weld it up the way it should have been from the factory....
06-14-2012, 08:48 AM | #14 |
I have heard of people doing as rob32472 said and I suppose I will do it that way. Was hoping there would be a way to save roof skin better but I do have a wide selection of cutoff wheels and a mini air saw that should make it less difficult. This isn't my first rodeo but I am no pro either. Have had such poor luck with "professionals" though that I would rather do it myself than dump a ton of money into someone else's pocket who is not passionate about old trucks the way that I am and therefore cuts corners. No, I don't want the markers because this is a lowered single cab short bed truck.
